  • Administrators
Share and Enjoy !
Shares
View the 2023 Legacy Elite & Legacy Elite II Victron SmartBMV 712 Display Monitor Manual by clicking the button below.
View
Share and Enjoy !
Shares
The post 2023 Victron SmartBMV 712 Display Monitor Manual appeared first on Oliver Travel Trailers.
Read the Full Article
Full Stack Developer/Marketing @ Oliver Companies
Oliver Forums Guidelines & Rules
A "heads up" for new owners (like us) who have the (more efficient) Victron charge controller instead of the older Zamp unit:  the wall-mounted Victron BMV-712 Smart Battery Monitor is exactly that--a battery monitor, not a solar charge monitor.  Since it is mounted in the same place as the old Zamp display, I presumed it reported solar charge data, like the Zamp did. It doesn't.  For solar panel output data, you must download and consult the Victron Connect app, and tap on the icon for the Victron charge controller, not the Smart Battery Monitor.  Then you can see not only current, but historical (last 30 days) solar charge data.
This is a paradigm shift which confused me until I figured it out.
