Dennis and Melissa Posted May 2, 2023 Posted May 2, 2023 I live in Tampa. Airstream has a huge operation 10 miles away. Could fix anything. That's comforting. 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
Steph and Dud B Posted May 2, 2023 Posted May 2, 2023 Few, if any, other manufacturer's dealerships will service an Oliver (or any other RV that they didn't sell) but most of the components in an Oliver are standard RV equipment and can be serviced by any RV tech. We use a local independent RV repair shop and there are mobile techs that will do it, too. For a damaged hull, others have used boat repair shops with good results. 4 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Patriot Posted May 2, 2023 Posted May 2, 2023 If you contact Mike Sharpe or Jason Essary at Oliver Service they could assist you with providing a recommended RV Service Center in your area. Oliver in the past has been selective on what service centers they recommend to perform work on Olivers. For any fiberglass work I would highly recommend Oliver - just MHO. Please consider listing your Oliver Hull# and tow vehicle in your signature area IF you own an Oliver. As members we can assist you better with questions on maintenance or other questions. Welcome and Thanks! Patriot🇺🇸 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
