Hello everyone,
I just noticed in my Ollie closet that underneath the black mat was wet with a salty liquid. The round port hole may have also not been tight in place. Anyone one what the salty wetness could be from?
Thank you!!
Christi, Matt, and Lucy
Explore, Dream, Discover
Christi, Matt & Lucy
2022 Legacy Elite II, TB
Hull # 1261
2019 F150 Limited
The caulk around my shower pan was too thin and the flexing of the pan opened up a crack and allowed water under the pan which wound up under the black mat in the closet.
I removed all of the old caulk and recaulked after placing a tractor weight in the shower pan to prestress the pan. Haven’t had any water under the black mat since doing this.
Bill and Martha
2019 Chevrolet 2500HD Duramax
@chiwald
Please post your Hull # and TV information in your signature block, it really helps members on here assist you with a solution.😊
Thanks!
Patriot🇺🇸
Thank you for the tips!!
Hull # 1261
2019 F150 Limited
On 5/28/2023 at 4:09 PM, chiwald said:
Hello everyone,
Thank you!!
Did you learn what the cause of this issue was? Would  you mind posting up any details and what you learned? This could help another member if they discover the same issue.
Thanks! 😊
Patriot🇺🇸
