aaronorange Posted June 10, 2023 Posted June 10, 2023 Does anyone know the Oliver factory breaker setting Xantrex freedom 3000. I set it to 20 while on a household 20 amp circuit but will be going back to a 30 amp service. Can I leave it on 20 amp? If I remember corectly it was set to 30 amp. But it would trip the inverter off when using a 20 amp houshold service. I see some people online set it to 25 or 28 amp. I did find this topic/thread but it did not answer the Oliver recomended/factory setting 🙂 Thank you! https://olivertraveltrailers.com/forums/topic/7081-dometic-ac-plus-xantrex-charger-on-home-20a-circuit/  Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD. Â
Galway Girl Posted June 10, 2023 Posted June 10, 2023 Inverter_Charger_Settings_Table.pdf This is from the Knowledge Base in the Support Section of the Oliver Website: 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG:  https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia. Â
rich.dev Posted June 10, 2023 Posted June 10, 2023 ...and then there's this from Oliver that shows it at 25A 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Rolind Posted June 10, 2023 Posted June 10, 2023 Here are the settings on our freedom xc from the factory 1 Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
aaronorange Posted June 19, 2023 Author Posted June 19, 2023 Thanks everyone! just got back from our 1st shake down trip. I was hooked up to a 30 amp pedestal so I tried putting it back to the original setting of 30 amps in the Xantrex app. That tripped the breaker, so I went to 25 amps and everything worked good. Hope this helps someone else someday. Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD. Â
