My new CO/Propane Detector says to disconnect power before installing. Do I need to disconnect a battery cable to shut off power to detector wires? Or, is there an easier way?
2018 Elite
TV - Audi Q5 3.0 TDI
Mine was powered by a positive and negative wire from the Ollie and connected to the positive and negative wire leads from the CO/Propane detector with crimped butt connectors.  The wires and butt connectors are probably covered by wire loom and should be visible under the aft dinette seat, near the detector mounting location.  After disconnecting the batteries via a cutoff switch or manually removing the negative cable, while working on 1 wire at a time, cut the wire on the Ollie side, the strip the wire insulation and crimp on a new butt connector.  Then repeat for the second wire.  Now you can remove the bad CO/Propane detector and install the new one.  Then crimp the new detector wires to the Ollie wires.
 I’m not sure, but I think the positive wire has a fuse under the street side bed, near the stabilizer jack fuses.  And don’t forget your solar system is also supplying power and if you can, cover the panels with a moving blanket.
If you have any further questions, let us know,
Mine did/does but the fuse was only about 6-12 inches from the rear of the detector.
If you are home - I would suggest installing a switch like both JD and I did so that when that detector goes off in the middle of the night you can turn it off quickly - after, of course, you have determined that it was a "false alarm".
