Jairon
Member+-
748
Jairon's Achievements
That was my plan initially until I got lazy. I'm guessing you've seen this but here it is anyway! https://gist.github.com/darconeous/8c7899c4d2f849b881d6c43be55066ee Let us know how it goes, even if you get lazy The cat5e cable fits nicely between the rear gasket of the trunk should you decide to change course. You can still lock it.
I suspect they asked for help with their lithium design and have about 3 different configurations based on some trial and error. I know my Lithionics setup is different from the LifeBlue setup. Both of those options were available for a bit due to supply shortages. Still, you'd think they would have wanted that stuff documented for the future. I was pretty bummed to find out but it is what it is. They also ramped up production quite a bit during that time. Still, no excuse. On a more positive note, we've had no issues with the trailer other than a busted window shade bracket and the silver trim losing adhesion in the rear. I can live with that.
After over a year of waiting, I canceled my initial Starlink order and went with the RV option. It shipped out the next day. The RV package has a clause for throttling if there is congestion but it works 1000x better than moving my cell phone around in the sky for 20 minutes to check the weather.
I'd avoid mounting it. The ground allows for better flexibility if your line of site from the camper is bad. The ground mount gives you a 75ft radius around your camper to work around trees and other obstructions.
I was looking for a simple way to use my rear storage compartment (the one that opens from the outside) to keep my Starlink router out of the elements / simplify setup and teardown. Running a new AC outlet from the main panel to the trunk is a straight shot but I wanted to review the electrical diagram before potentially ruining something. I contacted support for an electrical diagram and they still don't have one. They mentioned a third party was responsible for the design and this former employee/contractor is unable to provide it to them. They made it sound like Oliver doesn't even have an internal diagram. They did say ones coming off the line today will come with a diagram. For anyone that wants AC in the trunk and has a Xantrex XC inverter installed, I found this part: Xantrex 808-9817 which allows a GFCI outlet to be installed in the back of the unit. It was a nightmare to install but it works after you get the tiny screws back in... It ground faults without the screws and it seems to cut power to the outlet if the panel isn't flush with the unit (safety switch?). The installation requires the removal of the entire inverter or laying on your stomach and reaching deep under the seat to do a blind one handed installation. I opted for the blind install. Amazon link to part: https://smile.amazon.com/Xantrex-Freedom-808-9817-Electrical-Equipment/dp/B0756FZFZJ/ref=sr_1_1?crid=LV42YTTEUUIQ&keywords=gfci+outlet+xantrex&qid=1654812380&sprefix=gfci+outlet+xantrex%2Caps%2C90&sr=8-1
Unlike some of their other heaters, Caframo seems to be rebranding a generic heater for the one you mentioned. I just wanted to let you know because I've already gone down the space heater rabbit hole 😁 https://www.amazon.com/Ceramic-Adjustable-Thermostat-Protection-Certified/dp/B08RYNHVXH/ref=sr_1_37?dchild=1&keywords=PTC+Heater&qid=1617595031&sr=8-37
The "Hitch-It" system might work for those that don't have the storage box installed: https://store.lci1.com/hitch-it-double-bike-carrier-system-731138.html
Size of Generator needed to run Oliver ii AC
Jairon replied to Imelda's topic in Mechanical & Technical Tips
Thanks. The top looked odd to me, almost as if the blue section turned into a perfectly shaped Oliver pad. I've been on the lookout for a ladder. I appreciate the info! -
Does anyone know what ladder and ladder extension/pad that is? It looks perfectly formed for an Oliver. -
If the 2200 (1800 watt) generators won't start the AC, I'd strongly encourage you to consider having someone else install the EasyStart before buying a larger generator. They get pretty unwieldy after 1800 watts. The EasyStart is a very simple install for an RV shop and the part is way less than the cost of a larger generator. -
Your cushions look great! We're really happy we opted for the Ultrafabric. I was initially worried about the overall quality of the cushions in addition to the material itself but I'm happy to report that the fabric is great, the stitching is great, YKK zippers were used, and the foam is surprisingly comfortable. Your comments made me pull the trigger so I owe you one! Actually, I'll owe you one every time someone spills anything on the seats! 😁
It'll be enough provided you add the EasyStart option or install it yourself. -
I heard it was previously 100 pounds but recently updated to 150 Lbs. If 150 Lbs is true, I don't know if it only applies to the new rack design. Please let us know if you contact Oliver.
Oliver Elite II #748 Guts - 131 Images of the harder to see spots
Jairon replied to Jairon's topic in General Discussion
Agreed. I plan on doing a full review at some point with more detail and descriptions. I loved seeing photos like this when I was considering a purchase so I just wanted to dump them in an unorganized fashion for the time being. Yeah, I was bummed when I saw this too. I'd be curious to know if all of the new ones are like this and why. Practically zero heats makes it to the bathroom even with one of the vents completely closed. The person wielding the caulk gun should probably have their privileges revoked. It is a train wreck in almost every out of sight location. At least stuff like that can easily be resolved in the future. 😁 -
We had the air bags installed today. I didn't specify dual vs single path (before the installation, I didn't even know it was an option). It seems to be a hot topic like most things automotive but the mechanic went for the single path option. I can see advantages to both setups and the dual path is obviously ideal for unbalanced loads. The install was $263 from a mechanic we've worked with for a number of years. Thanks to everyone giving advice in this thread and especially @John E Davies. We're extremely grateful! P.S. Don't let my optimism prevent anyone from ripping on the single path setup. I'm happy to hear everyone's thoughts about it
