Tideline77
Location
Alabama
1218
2022
Tideline77's Achievements
The Entrepreneur made twin M 18 battery housings listed on eBay and ESTY would be the cats meow . They must be three D printed plastic if these makers could take that idea one step further and use a short pole to get the mini out of the brush or grass and maybe get a little better sky reception Hope I didn’t derail this thread two much 🙄🙄🙄
Edit AI search shows the APP sleep mode can be set via APP sleep mode is not a complete shutdown but is a low power mode designed to conserve battery use so its sleep mode you want to set on your APP ——————————————————— For sure Need to review the APP to confirm this because my mind and memory are not 100% anymore. Plus I only played with it for 3-4 evenings i can get mine out tomorrow and double check
We just got our mini and activated it from our home base, then switched the subscription to pause so I am not too swift on the operation but I thought I saw the option on the phone APP to turn off the mini via IPhone so I thought it could be turned off by APP without us streaking in our camp site also on ETSY and EBay are some pretty cool offerings that accommodate two batteries and have a small shroud cover that covers the batteries and holds the mini giving the batteries a small amount of weather protection look pretty neat to me
our Ollie has the 390 AH lithionics system and we often camp without power connections Power usage onboard using the inverter is mostly a coffeee pot and and water kettle every morning , we think we are light power users When the mini is deployed away from the camper to get clear sky , Is it a reasonable idea to power our mini with two Milwaukee Forge tool batteries ? we have the batteries in our tool box with a few Milwaukee M18 tools , inflator, impact wrench for tire emergencies rolling out and rolling up a power cord seems like a burden "………….after doing it for 45 years our internet use while traveling is just web surfing and maybe an hour of movie streaming here and there.
Tideline77 started following Where’s Ollie? , Oliver reborn! , Self-adhesive Shower Curtain Track Recommendations and 7 others
Furrion Chill Cube – Product Review and Installation
Tideline77 replied to jd1923's topic in Ollie Modifications
Agreed, but... Looking at the specs I see a 3.25" difference (14.5" - 11.25"). It would be 5" to your low-profile Houghton. I promised @Tideline77 measurements which I took yesterday. My son Adam climbed up the scaffolding and place an 8' 1x3" on top of the A/C unit hanging off to the curbside. I measured the height and did not believe the number, so I measured it in the same way off the streetside, same number! I measured exactly 9' 8.5" on BOTH sides! This is great news and thank you for measuring ! 👍🏻👍🏻👍🏻 -
What is Towing "Level" and Does It Matter?
Tideline77 replied to Sam Heumann's topic in Towing an Oliver
After struggling to get our F150 dialed in level using the Andersen WD hitch along with RAS suspension upgrade due to excessive suspension squatting we never got things adjusted to our satisfaction I am adding the Bilstein 5100s on the rear of our F150 along with the airlift bags. Will be removing the RAS road active suspension system . With the ball height set correctly we never could overcome the squat on the F150 hoping for a much more enjoyable towing experience once we get it dialed in unfortunate that the RAS didn’t work out on our truck, maybe I can sell the used RAS and recover a little bit of the loss I had understood our 2018 F150 with the factory tow package came with upgraded shocks ( better than stock shocks on F150s without the factory tow package ) but this truck squat is extreme when we lower the bulldog on the ball I do need to go back and refresh my memory on adjusting the Andersen Hitch Andersen Owners manual page 11 covers level trailer and tow vehicle -
Will you be making a thread on the installation of the chill cube for those of us that want to follow along ? and once you get it on the roof we would like to know the final increase in height above the stock dometic unit ! -
Tideline77 replied to Wayfinder's topic in Mechanical & Technical Tips
Would you share the cost and the online vendor and part number for us ADD folks ? -
Installing Pioneer Inverter AC
Tideline77 replied to Treasure Coast Vault's topic in Ollie Modifications
Don’t know if it is correct or incorrect but I was told Pioneer is owned by Gree -
Noted on the 2022 with the 3500 lb capacity axle label to keep an eye on this just greased the suspension and they have a nice arch and only 6000 miles #1218 LE II
Did I understand this right ? The 2022 year models forward are in jeopardy of broken springs ? somehow I had come to the conclusion that they were not ! but I am a little slow keeping up
Tideline77 replied to John and Jodi's topic in General Discussion
If you are considering getting a battery operated impact to carry on your travels ? These tools are expensive 🤔 but there are usually promotions and sales that you can wait for that offer steep discounts and even then they are expensive After considering one for a long time this thread kicked me over the fence and i snagged a Milwaukee 1/2” drive M18 model #2962-20 during a recent sale $189 with a 5 amp battery and a charger #2962-20 😳 $489.00 is the regular price Next I need to snag a heavy duty plug kit…….and TPMS for the Oliver You can search for sales on Search this page -
in case the OP doesn’t reply I will chime in his Signature shows 2022 year model hull pretty sure that the 2022 year models got Coopers My foggy memory thinks that Michelin tires were the Oliver spec but Coopers were substituted due to supply chain issues ………Covid our 2022 has Coopers as many others have -
I didn’t want to start a new thread with this simple question , so I apologize for piggyback riding on your install thread We are ordering the starlink mini while it’s on sale at $229 what other accessories do we need to order from starlink when we enter our order ? need to get it done with one order if possible
