The Loonies
    880
883 profile views
The Loonies's Achievements
Rookie (2/14)
11
  1. Thank you all....great info from Steph and Dud B.
  2. We have to leave our camper for 7 days in Southern CA where there is endless sun. Has anyone run the refrigerator strictly on solar for that length of time? There will be no other energy draw as it will be empty. We have 3 Lithionic Batteries 400 AH, 340 Watt Solar Panels. Trying not to use propane if possible. We realize it is the most efficient way, but we are interested in testing the limits of our solar package
  3. There is a small hole next to the USB port for RESET. Insert a pin and hod for a few seconds, the Furrion wi reset. Yes, prior Bluetooth connections wi be gone, but it is easy to reconnect.
  4. Thank you all for suggestions. I called Furrion after nothing worked and they walked me through a hard reset of the system. That solved the problem.
  5. Have successfully connected to BT with my iPhone in the past, but now I cannot connect. Furrion display states "LINK OKAY", but I still can't connect. I have deleted the old connection on my iPhone and tried to reconnect but it just keeps searching for the connection. Any tips and tricks will be appreciated. Ellie Kelly
  6. Problem solved.. Thank you to everyone who replied especially rich.dev for the tips and tools needed. Happy New Year
  7. Has anyone replaced the city water connector on the Legacy II ? Ours is leaking and would appreciate any input on replacement part as well as install tips. Thank you, Ellie
  8. I am trying to replace the power cord for the ProBreeze PB-03 and the company does not sell one in the US for this model. I found this one on Amazon but I do not know if it is the voltage is too high. Back of the unit lists voltage as 100-240V. I would appreciate any input. Thank you, Ellie https://www.amazon.com/Listed-Cable-Replacement-Power-Prong/dp/B0025ZPX6O/ref=pd_lpo_sccl_1/138-7514323-5978269?pd_rd_w=8igA7&content-id=amzn1.sym.116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_p=116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_r=KJTVH89RRQCQE1BB2EXJ&pd_rd_wg=aOTTL&pd_rd_r=7031f99a-eb09-451e-b671-9fb8cc71f5a0&pd_rd_i=B0025ZPX6O&psc=1
  9. Hi, The bathroom valve was in the closed position but water was leaking in through the shower drain. We found that the silver cylinder was not seating as far down as it should. Was able to push it down manually, but I have to reseat it every time I pull the cable to open it. Will be adding RV tank lubricant asap, but is this a cable issue, valve issue or both? We are the second owners and just picked it up last week. Any input appreciated. #880, 2021 Legacy Elite 11
