GeoffChapman
GeoffChapman last won the day on October 17 2023
GeoffChapman had the most liked content!
1 Follower
    Pittsburgh, Pa
    731
    Legacy Elite
GeoffChapman's Achievements
Enthusiast
Enthusiast (6/14)
80
  1. Bill, thank you!! The fuse on the side of the battery compartment (not the one in the photo) had been tripped. Reset it and Success!! Pump and the rest of the 12v system came on. Winterization is now complete. Thank you all!!!
  2. What is this switch? Might it cut off the 12v system?
  3. I have pushed the power switch on the Xantrex and on the Remote. The remote lights up, as does the Xantrex. Are these button switches 'on' when depressed (in) and 'off' when out? Should the Xantrex be "out" and the Remote be 'in'?
  4. Need more help, please. I have put the lithium batteries back in, unplugged the shore power and the FreedomX Remote Panel with the Xantrex Freedom XC 2000 Inverter both are running and supplying power to the 120v system. The 12v system does not come on. Is there a fuse I've thrown - or a switch on the inverter that needs to be pushed to make the 12v system come on?
  5. Need some more guidance, please. I'm not very experienced at electricity, but I am game if it is safe. Forget the Jackery. Can I use one of my 12v lithiums instead? "With all other loads turned off (as to not overload the Jackery) just hook your Jackery neg to the ground buss with all the yellow wires, and the Jackery positive to the big red wire input of your 12 volt fuse panel . Your pump will then operate as normal. " Looking carefully - here's my shot at a safe 12v power disconnect the 120v land line take one of my lithium batteries, turned off and use a jumper cable, connecting the: negative to the 'ground buss with all the yellow wires' and positive to the naked bus on the far side of the 12 volt fuse panel? (left side of photo) turn lithium battery on turn off all 12v lights, etc turn on water pump and finish the winterizing Is this good? Corrections? Happy Thanksgiving!!!
  6. Was wondering about that. I haven’t looked carefully at the pump motor, and there will be no 12v power to run a test. Any wisdom on which lead is + or -?
  7. Thanks Bill. I wonder - what if I were to use 12v leads off my Jackery battery and connect them directly to the leads of the pump? All I want to do is run it for 5 minutes… Thoughts?
  8. I have an Oliver Elite 1, 2020. I was winterizing it and before I winterized the outside shower station I removed my lithium batteries and remained connected to shore power. When I went to turn on the water pump, it did not come on; the entire 12v system is not working, while the 120v system works fine. I called Oliver, and they thought I probably have to put the batteries back in to make it work. Does anyone know if there is a way to get the 12v system working without any batteries in the Oliver. I have the FreedomX Remote Panel with the Xantrex Freedom XC 2000 Inverter. Thanks for any help!
  9. Before I got the lithiums in March, I’d been turning the inverter off with the button on the inverter under the aft dinette seat - rather than with the button on the remote. It was my impression that completely shut it off and eliminated the draw from the inverter - whereas turning it off with the button on the remote kept it on standby, hence the small draw. True or not? Geoff
  10. We just returned from a 5 week trip west in our 2021 LE1 with 260 AH of lithium newly installed and 300 W of solar - 200 W on top and an outboard extra 100W panel. We had several 5-day boon docking sessions and never had a problem with keeping power around 100% - or getting it back up to 100% after a cloudy day. BUT, we had mostly sun and we have the 3 way refrigerator running on propane. The bigger challenge in boon docking was running out of fresh water, or needing to dump grey or black tanks. Full time would need water and sewage hookups, at least, we suspect. And electricity via shore power or a generator in cloudy seasons. One other challenge - we needed to develop careful choreography and rhythms to live well in a tight space. And our dog had to learn them as well!! We actually had a lot of laughs as we figured them out!! Geoff
  11. I’m new to the Oliver community, just 7 months into my new-to-me LE1, so take my thoughts with a grain of salt. I offer them with some humility, honestly. Here’s my thought: I'm surprised at the negativity about the developing Oliver sales and service model. My own service experience is quite limited to a week in Hohenwald a month ago - we’d timed it to launch our current 5 week camping trip. Our planning went back to a service request 4 months ago. When the date came, we traveled 2 days to get to Hohenwald, and then had to find accommodations for 4 nights for me, my spouse and our dog to wait out the 3.5 days our upgrades and annual servicing would take. We were happy with the results and the knowledgeable team we met, but would have been much happier if a regional Oliver dealer was available for a “drop it off and come back in a few days to pick it up” kind of servicing last winter. The jobs we had done (lithium & Truma AC upgrades & annual servicing) would have been well within the ability of a competent and well trained regional dealership. When the dealership expansion was announced, I did contact such a regional Oliver dealer in lower Va. They told me they had not yet been trained for servicing, so I kept my March appt at Hohenwald in place. I thought, “Training dealerships has got to take some time. Check back with the regional dealer in a year and they should be up to speed.” That seems (to me) a reasonable expectation for the Oliver community, with widespread benefits for Oliver owners like me in the years ahead. From what you all are repeatedly saying about the Oliver family and team, I’d have a high confidence that they share that goal. If everyone’s experience with the Oliver team in the past has been so widely appreciated, why not give them the benefit of the doubt? In the meantime, I feel confident that I have a backstop if I get caught - you all. I’ve been a regular reader (if an infrequent poster) in the Oliver forums over the last half year. I’ve seen you all step in again and again to help people like me, who are trying to make something work better, or fix something broken. The generosity, creativity, competence, and enthusiasm of the Oliver owners was a factor in my purchase. Were I in Oliver management, I would hope for your partnership in making this expansion as seamless and fruitful as possible. i suspect as a newcomer to the Oliver community I’m missing something here - maybe it’s the longstanding friendships that have developed in the Oliver community. Maybe it’s something else. I just hate to see a much loved team with a first class product and a devoted family of owners fracture like this when some (well deserved) trust and some months of patience and a “let’s do what we can to make this work” attitude could make a good thing even better.
  12. I’m glad to know there are others in this group! I dented my bumper on my first trip 7 months ago on my way home with my new to me 2021 LE1, turning too sharply on a Hipcamp lawn. I’d never towed before that trip and had no idea I could do that!! Thanks @Geronimo John! Will check my bulldog for cracks!
  13. Does this clear the P-traps in the kitchen sink, bathroom sink and shower drains?
  14. Well I for one am glad the thread was updated! I'm new to towing, with my new-to-me low-milage 2021 LE l, and just inflated my OEM tires to the sticker pressure (80lbs). After some short trips (4K miles of towing), I got a Tireminder and noticed my tires going up about 10% in pressure while towing. Seemed high to me, so I decided to double check and ran into this and a couple other threads. I'm now running them at 60lbs. It feels much smoother! Thanks for bumping the thread forward! Geoff
