I did not realize how beneficial the electric jacks could be until this week when I have been camped in spaces with a lot of fall. The jacks enabled me to achieve level with a minimum of effort whereas with the scissor jacks or leg jacks other trailers have I would have become very agitated to say the least.
Go Olliver!
The jacks are awesome.
We still carry some 2 x 8 cutoffs to stack under the jacks for extended throw. Our jacks in the older models may be shorter, I don't know, but we don't like to take the jacks to the limits.
So much nicer to touch a button than crank, crank, crank.
Sherry
I carry a pack of the yellow Leggo type blocks for placing under the jacks. Don't like to extend all the way either as it puts too much strain on the legs, and the trailer sways less with shorter entension.
Seriously, the trailer sways when jacked up by these jacks? I had definitely planned to bring along some 2x6's but your observations sounds a bit spooky.
Legacy Elite II #70
Routlaw,
I'd have to say I only notice sway when we do not deploy the jacks. As quick as it is, if we're just overnighting, we often don't bother to unhitch and deploy the jacks. Then, I feel some sway. Not noticeable with the stabilizers down, imho.
We use the 2x8 or 2x6 blocks to give us a greater surface against gravel/mud, and to avoid using the total throw of the jack. We don't like to take the jacks to the absolute limit, and I think our jacks on the older 2008 are a little shorter, anyway, than the new trailers.
Sherry
Do you folks notice much battery draw when deploying the jacks?
Seems like they could be big energy users but I'm just guessing.
Either way they're a great idea.
Dave
2015 Oliver Elite 1, Hull 107
They are a momentary use item. I've found them to be an insignificant draw on the batteries when I set up camp. And your right, their usefulness waaaay outdoes the small battery draw.
