I am ordering parts to do some Maintenace on my LE2 suspension.
Mine was manufactured in 2019, came standard with the EZ-Flex and currently has a little over 62k on it.
I am hoping to get answers to a couple quick questions:
1:  Does the center pin of the EZ-Flex have a serviceable/replaceable bushing and if so, is it the same size and type as the bushings on the spring ends?
2:  Likewise, do the two outside holes on the EZ-Flex have replaceable Bronz bushings like the spring ends?
Thanks in advance.  .sj   #512
sJ,
This may be of help.
https://www.etrailer.com/question-431835.html
David
Edited by Patriot
If it is magnetic, it's not bronze or brass.  It has Iron.  Will work, but it's not the best... IMO.
