johnwen Posted January 16 Posted January 16 25 minutes ago, johnwen said: JD, not that it matters much but my unit is a 2000w pro. I will retest now. JD, After changing the setting I disconnected shore power and this time all worked fine. Last (and only) time the inverter came on for a few seconds and shut off. Maybe something else was going on...but for now it's ok. Will check again at the "Q". Thanks for the help :) John 2 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
johnwen Posted January 16 Posted January 16 On 1/14/2025 at 6:36 PM, rich.dev said: I can do that with my Xantrex 3000. Go into the Xantrex app, scroll down to Charger, click on "Charger Ignition Control", swipe up to change "off" to "Auto-on" then click "apply". Thanks, rich.dev I think problem may be solved :) 1 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
