LeBill Posted April 23, 2024 Posted April 23, 2024 Towing my Elite I with the Anderson hitch, I've encountered a lot of forward / backward sliding of the square shank within the receiver mount on my truck. It has been a cause of annoyance at stops and starts as the entire hitch can be felt sliding. Upon investigation I found that the hitch pin I was using is slightly undersized, as were most of the other pins in my garage. To remedy this, I took my calipers to Tractor Supply and mesaured every hitch pin on the shelf. The BROK locking hitch pin was the winner, at about 0.8mm larger diameter than the one I previously used. I also installed some rubber 'donuts' around the exposed shank to take up the slack. together these two measures have almost totally eliminated to back and forth mothion of the Anderson ball mount LeBill Elite I Hull 1352 2021 Jeep Gladiator Northwestern NC (retired)
LeBill Posted April 23, 2024 Author Posted April 23, 2024 Impresa Products Impresa - 2 inch Hitch Receiver Silencer Pad for Adjustable Ball Mounts - 3 Pack LeBill Elite I Hull 1352 2021 Jeep Gladiator Northwestern NC (retired)
Moderators topgun2 Posted April 23, 2024 Moderators Posted April 23, 2024 (edited) Did you mean THESE things for your link? Or These on Amazon? Bill Edited April 23, 2024 by topgun2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
jd1923 Posted April 24, 2024 Posted April 24, 2024 5 hours ago, LeBill said: ... Upon investigation I found that the hitch pin I was using is slightly undersized, as were most of the other pins in my garage. They make hitch pins in several sizes for tractor equipment, etc. Yet the standard 2" tow receiver always takes a 5/8" hitch pin or lock. You have the right one now. Just 0.8mm smaller, which is very close to 1/32", I've never seen that size. There may be a 9/16", but the next standard size smaller is a 1/2" pin and that is 1/8" smaller, over 3mm. A smaller pin would certainly bang around a lot and is NOT safe at all. The 5/8" hitch pin or lock is all you really need. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
LeBill Posted April 24, 2024 Author Posted April 24, 2024 All of the hitch pins I measured were 5/8 nominal size. I found there was considerable + / - tolerance, not to mention the hole variances. My original hitch pin was an inexpensive locking one, probably made to loose tolerances, and was already showing wear (8000 miles). It remains to be seen how well the new hitch pin and rubber donuts hold up. I used 5 of the donut pieces stacked on the Anderson square piece. It is so stacked that I need to apply pressure to compress the rubber donuts in order to fit the hitch pin in the hole. 1 LeBill Elite I Hull 1352 2021 Jeep Gladiator Northwestern NC (retired)
Geronimo John Posted January 9 Posted January 9 Sorry I'm a bit behind on this thread. On my 2019 F-150, the 2" Anderson Receiver with 2 5/16" ball is slightly smaller than the Ford receiver. The hitch pin/hole are right sized. So the "Slack" I see when jacking my Ollie up to undo Anderson chains is actually a rotational arch with the hitch pin and hole acting as a swing point. Not slop back and forth. This arch is actually beneficial as when I see it swing those few degrees, I know it's time to stop lifting. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
