Moderators topgun2 Posted June 9, 2024 Moderators Posted June 9, 2024 In our small town here in western North Carolina we have a "small" WalMart. As with most WalMarts, there is a "Clearance" section and even some departments within the store have their own "clearance" areas. In the Automotive section of our WalMart they currently have Prestone RV anti-freeze on clearance for $2.00 per gallon. This stuff is rated to -100 degrees. While I always try to have at least a couple of gallons in my workshop, I just could not resist picking up an additional few gallons at this price. Bill 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rideandfly Posted June 9, 2024 Posted June 9, 2024 Will check out our local Walmart, hopefully they have the same price. Thanks, 1 Bill 2015 LE2 #75 2024 F350 6.8L
Patriot Posted June 9, 2024 Posted June 9, 2024 I checked my shelf stock and I am good! Thanks for the heads up. 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
