DunnYet Posted June 15, 2024 Posted June 15, 2024 Ollie LE II Owners - we are the second owners of the Hull #1364. The original owners did not have the closet bar installed, and the screws that were in the hangers are WAY too long for purpose. If someone could post a photo of the way the factory mounts the closet bar in the II it would be much appreciated. Thanks very much - Kevin Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner) Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver" Original: 2022 Oliver Elite I - Hull #1030 "Reset" (Sold) Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose" Home Base: Duncanville, TX
MAX Burner Posted June 15, 2024 Posted June 15, 2024 10 hours ago, DunnYet said: If someone could post a photo of the way the factory mounts the closet bar in the II Our closet rod hangs from below the lower shelf with brackets having 4 x 3/8" stainless flat head screws, FYI: Hope this helps out... 2 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Patriot Posted June 15, 2024 Posted June 15, 2024 @DunnYet Same closet rod connectors as @MAX Burner. I bet a quick call to Oliver Service would get you exactly what you need to install the closet bar. Oliver Service is great about shipping fairly quickly in my experience. 👍🏻 2 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
