rideadeuce Posted June 25, 2024 Posted June 25, 2024 Pretty simple setup if you have a Victron system. I got the new SeeLevel display that has extra 4 pin connection for sending information to the Ekrano/Cerbo from https://www.vanlifeoutfitters.com/store/seelevel-709-n2k-pm-tank-monitor-kit-for-cerbo-gx/ You do not need new tank sensors. 2 4 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
katanapilot Posted March 10 Posted March 10 Reviving a bit of an older thread as I am installing this same panel now. Does anyone have the part number of the three way switch located in the bath that operates the water pump? As this newer SeeLevel panel does not have a pump switch, I need to replace the one in the current SeeLevel panel that I am removing. 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Snackchaser Posted March 10 Posted March 10 That would be a "Single Pole Double Throw" (SPDT) switch. I buy my switches from DigiKey company, PN CH876-ND. If you message me privately, I can send you an extra one I have. 1 1
katanapilot Posted March 11 Posted March 11 16 hours ago, Snackchaser said: That would be a "Single Pole Double Throw" (SPDT) switch. I buy my switches from DigiKey company, PN CH876-ND. If you message me privately, I can send you an extra one I have. Thanks so much. Private message sent. 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
katanapilot Posted May 27 Posted May 27 (edited) Probably a bit unusual of a question, but - What configuration settings are used with 30lb propane tanks and Mopeka sensors for the Cerbo? Specifically, the tank capacity (7 or 8 gallons) and empty and full sensor reading height? I had guessed about 20 inches (50.8cm) for full height, but not sure that is correct. And did you have to rewire the connector to the SeeLevel when you replaced it with the newer panel? I tried the connector removed from the original SeeLevel and it did not work with the new panel. I'm not referring to the RJ-45 connector that goes to the Cerbo, but the original one that gets power and data from the fluid level sensors. Edited May 27 by katanapilot added text 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
rideadeuce Posted May 28 Author Posted May 28 Yes, you have to order new panel from SeeLevel that will connect to Victron system. Easy to switch out. The chart below may be helpful. 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
katanapilot Posted May 29 Posted May 29 9 hours ago, rideadeuce said: Yes, you have to order new panel from SeeLevel that will connect to Victron system. Easy to switch out. The chart below may be helpful. Thanks for the chart. That is the info I was looking for. As to the SeeLevel - I did purchase the new panel with the Cerbo connector. The panel did not work when connected to the existing Molex connector. Do you know if this panel gets its power from the Cerbo connector or the standard connector? 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
rideadeuce Posted May 29 Author Posted May 29 (edited) 3 hours ago, katanapilot said: Thanks for the chart. That is the info I was looking for. As to the SeeLevel - I did purchase the new panel with the Cerbo connector. The panel did not work when connected to the existing Molex connector. Do you know if this panel gets its power from the Cerbo connector or the standard connector? 3 hours ago, katanapilot said: Thanks for the chart. That is the info I was looking for. As to the SeeLevel - I did purchase the new panel with the Cerbo connector. The panel did not work when connected to the existing Molex connector. Do you know if this panel gets its power from the Cerbo connector or the standard connector? The red wire from the 4 pin connector, I believe. I am not an expert on this, always have to call myself. Where did you buy the new Seelevel panel? Vanlifeoutfitters was very helpful for me. I had actually got one of the 4 pin connectors loose stuffing it in the hole and finally after taking out and putting it back a couple of times got it back working. Also, the settings for the Ekrano were different than what is needed for the Carbo. Again, I would call Vanlife if that is where you bought the panel, very knowledgeable and helpful folks. Edited May 29 by rideadeuce - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Moderators mossemi Posted May 30 Moderators Posted May 30 (edited) This link contains the information I used to connect and monitor the SeeLevel tank senders and a Cerbo GX. https://www.vanlifeoutfitters.com/using-seelevel-tank-monitoring-with-a-victron-energy-cerbo-gx/ Mossey Edited May 31 by mossemi Typo 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
