  • 1 month later...
Geoff,
Thanks for this post and excellent write up. I used this for my Airstream and performed some additions like powering a WiFi and adding a RJ45 to the external connector. The power relays are awesome too and I know I will find uses for them on other projects.
Hello Geoff,  I loved the install you did and the write up and pictures were very helpful.  I tried to install the same converter from Victron , but I am having a little trouble. I did not install an on/off switch and left the jumper in the remote slots. I have a solar panel connector on  the outside of the van (SAE type), which I intended to use but was never hooked up . I am using that as the outside connection to power the Starlink. The adapter that I used is an SAE to RJ45 to connect to the Starlink antenna. I adjusted the output voltage to 30 volts at the Victron Orion and measured the voltage to outside connector. The problem is I cannot power up the Starlink( no light) on the antenna, but power light is on the Victron Orion. Works fine when I plug into the 120 in the van. Wondering if you had any suggestions. Tim
Hi Randy,
I’d be happy to help you, and the first thing that comes to mind is polarity.  Some of the SAE solar connectors are intentionally wired backwards for specific solar chargers.  In fact you can get polarity reversing connectors for them.   Check that out first thing.
However, I’m a little confused that your using an SAE to RJ45 adapter?  We should first confirm that you're hooking up a “Starlink Mini,” which is completely different from other Starlink units.  The Starlink Mini has an RJ45 connection, but it's not a power connection.  You must use the 5.5mm barrel power cord.  Other Starlink units are powered differently and this modification will not work for them.
There are 5.5mm to SAE adapters that could be used in your application, if you are in fact powering a Starlink Mini.  The picture shows one from Ebay with a polarity reverser included.
I hope this helps and please feel free to contact me privately is you have more questions.
Cheers, Geoff
Hello Snackchaser, You were spot on with your advise. It was indeed a polarity issue and I verified that by switching around the pos/neg at the Victron. I have now ordered the 5.5mm to SAE that corrects the polarity issue. Love the Starlink Mini. Thanks again.  Tim
hello and first of all thank you for your post concerning the mini's 12v power supply.
I want to do exactly the same thing and I'd like to know what programmer you use for the timer.
if you have a link amazon or other it would be great!
thanks again
christophe who follows you from france!
  • 3 months later...
On 7/13/2024 at 9:30 PM, Snackchaser said:
It also has an RJ45 port that I suppose is for hardwiring without WIFI, but I probably won’t ever use that feature.
Thanks Geoff, for again being a leader in technical electronic HW installations! Not easy to pair compatible electronics with so much in the marketplace!  😂
I will add a Starlink Mini at some point. Hope the HW prices keep coming down! Like the $50 monthly service option for the limited data plan. I would merely use the included 120VAC power adapter since we run our Victron MP2 inverter ON always.
You wrote you would not "use that feature" but given I have a smart Pepwave router that can chose between 4-5G cellular service (T-Mobile monthly business plan with unlimited data) and a WAN RJ45 input, I'm hoping this is compatible in the way I'm thinking. This way you have one Wi-Fi login for all devices, not having to switch to a Starlink-only Wi-Fi.
I would manage the settings to prefer cellular connection to minimize Starlink data usage for when it is truly needed. Has anybody else integrated cell and Starlink services in an onboard router? I will ask tech support at MobileMustHave.com where I purchased the Pepwave system for configuration help, and will post later when I get their answer.
Another question is does the Starlink Mini have to be positioned at an angle? Thought I read somewhere it should be pointed at the northern sky. The manuals just show 110 degrees unobstructed is necessary. I see rooftop mounts that are flat and pole mounts that are angled. Can it lay flat to the horizon to receive signal or must it be angled? Best wishes and thanks again. JD
Awe thanks, but you probably know more about it than I do!
There is great information about using a Pepwave with Starlink on the YT channel “Mobil Internet Resource Center.”  People primarily use them for better reliability and stronger WiFi for increased speed, and they would certainly supplement the 50 GB Starlink roaming data plan.  The Starlink Mini’s built-in router is not as powerful and the speed decreases the further away it is.  We usually get 100 to 150 mbps with the mini compared to reported speeds of 300 when using aftermarket routers, which is about the same as our Gen-3 dishy at home.  However, 100 mbps is still a respectable speed.
We’ve exceeded the 50 GB limit a few times.  So we just pay for the extra GB’s as we go.  The real expense is the extra snacks and cocktails for internet mooching visitors 😉
I seen Starlink dishy’s laying flat, but not a Mini so far.  Not to say it wouldn't work!   I think orientation is more important for them because of the small surface area.  The kickstand and pole mount are angled and the Starlink App lets you know if they’re not pointed in the right direction.  Which seems odd to me because the Mini is approved for mobil use and Iv’e wondered how well that works considering they're directional??
I found a Victron Orion TR 12/24-5, isolated, DC to DC Converter, and it was perfect for the job.
Yesterday I wrote I would use the 120VAC adapter for the Starlink Mini. My router and cell antenna are truck mounted. The RJ ethernet connection to the Pepwave would be at the interior rear wall of the truck cab (see pic). I run the router off the dual Ram batteries that I had recently upgraded to AGM. I have a simple power switch under the hood but when camping the Pepwave is always powered ON.
I need to measure the AH draw of the Pepwave. From experience, I know it can run 3 days with ample voltage remaining to start the truck. I also have a 50’ extension cord and 10A charger in case of trouble. Wonder if the truck batteries can take another  2AH overnight, the number Geoff mentioned for the Mini while streaming. I would add the Mini with Victron Orion-Tr 12/25-5 to the truck if possible.
Though it may be simpler to just pull out the Starlink when cell signal is too low. Love the truck mounted router and would like to integrate the two. We can be on a day trip or sitting in a restaurant and we have our own Wi-Fi. The 2.4GHz band over the Parsec antenna has easy over a 100’ range!
So curiosity got me and I powered on the Pepwave, truck sitting in driveway. Connected my living room TV and my cell phone to the 2.4 band. Streaming a news show inside and ran Ookla Speedtest on my iPhone. The test got 95 Mbps down and 50 up, on the phone with the TV streaming. The Pepwave pulled between 0.10A to 0.17A. Call it 0.14A on average, amazingly efficient! No wonder I can leave it powered on for days.
The 2A draw for the Mini is likely too much for truck batteries. Could I use the 4 AWG cabling for the DC-DC charger setup in reverse direction to power when parked, hmmm?
What is your cell phone speed without the Pepwave for comparison?
The DC to DC charger will not work in reverse, otherwise it would charging the truck battery.
The Victron is still a good option when using the Starlink supplied 50’ cable, which is really desirable when trying to find clear sky view when camping around trees.  Starlink now offers a 16’ USB cable for in-motion use that would be a better option for the truck.
The DC to DC charger will not work in reverse, otherwise it would charging the truck battery...
The speed is not the issue as I just wanted to see power usage when the Pepwave was busy. But since you asked, I measured again this afternoon. This time on the 2.4 GHz band I got 105 down, 13 up. On 5GZ it read 340 down and 70 up and on 5G cell with Wi-Fi turned OFF is was 716 down and 39 up. Where the truck is parked the antenna is blocked by the garage. When I back it away from to the building even 20 ft the numbers improve.
You wrote, "...it would be charging the truck battery." That's what I would need to run the Starlink Mini on the truck batteries. Maybe I could install a switched relay in the DC-DC cabling. Charge the Oliver batteries when towing and throw a switch to bypass the DC-DC charger, when camped, to hardwire the 600AH LiFePO4 in the Oliver to supply the drain caused by the Mini.
  • 2 months later...
Geoff, please give this another thought. I believe you are our resident electronics and switching expert! 😂 Could a relay or something be added to work out this need?
I will install the Orion-XS DC-DC 50A non-isolated charger to charge the Oliver house batteries while driving. I have our Pepwave router system installed in our truck, our Oliver tow vehicle (pic 1) and I plan to install the same Orion-TR 12|24 5A converter that you have installed along with a POE switch to wire the Starlink Mini, right next to the Pepwave behind the back seat of our truck. You can see I already planned on the cable entry and ethernet cable is ready. I have a simple toggle switch under the hood to cut power to this system. Presently, I only turn it off when we are parked at home for some time.
For over a year with the Pepwave in the truck, we could run it for 3-5 days without worry to the starter batteries getting too low. Adding this converter and a Starlink Mini will take greater power consumption and I worry whether it could even make it an overnight camping!
So, could I throw a relay switch to hardwire the 4 AWG wire, bypassing the DC-DC charger so that the house batteries are wired directly to the starter battery? Would charged LiFePO4 batteries at 13.3V or more connected to lead-acid starter batteries at 12.6V hurt anything? Would it bring down the voltage of the house batteries? If not, I could be running the router system with Starlink Mini connected and running to the truck circuit with amperage drawing from the Oliver batteries, where we have a total of 600AH available.
It's an odd requirement I know, but we love the Pepwave with Parsec Husky in the truck where it will stay. I use it for back-up internet at home where T-Mobile has 5G service. We use it sometimes while driving and I understand the mini works decently while driving. The Husky is so powerful that 5GHz Wi-Fi 6 surrounds any campsite and much further if you need the 2.4 GHz channel.
MobileMustHave claims the Starlink Mini is more efficient running through the Pepwave and the router can be setup to prefer cell where we have unlimited bandwidth when available, over Starlink with the 50GB monthly package.
Lately we've camped at a LOT of locations without cell service, so it's time for the mini! I'd want it installed driver's side of the Parsec (pic 2), with an ability to dismount it, add another length of Ethernet cable when we need distance to get to open sky.
Thinking of getting this magnet-mount case Trio case: https://www.trioflatmount.com/products/minispeedmount
Edited by jd1923
Yes me John. I have my Starlink G3 and cell going through my peplink max br1 pro 5g. Here are the YouTube videos that helped me set it up.
Edited by rich.dev
**Sold😞**
Thank for this, Rich. Hope your travels are going well!
Was the mini available when you went with the G3? Wanted more speed or other reason for the G3? Thanks again!
No
**Sold😞**
1 hour ago, rich.dev said:
No
Man of few words (until we meet again in person)!
TY!
JD, unfortunately it’s true that the DC to DC charger does not pass current in the opposite direction to back-feed the truck, otherwise the trailer battery would try to equalize with the truck battery and it could act like a charger in reverse.  This is also why the DC to DC charger uses an engine-on sensor to turn it on, otherwise the truck battery would try to equalize with the trailer battery when the engine is off.
If you want to use your DC to DC charger cables to run your Mini/Pepwave from the trailer battery, then you would need a relay to go-around the charger on the trailer side, and another (50 amp relay) to isolate the battery on the truck side.  Then you would need switches for both with an interlock for safety.  It’s rather complicated and expensive, not to mention relay parasite current.
A better idea is to use the +12vDC wire from the 7-pin tow harness.  It should be spared already on the trailer side, and you would have to isolate it on the truck side to use it as a trailer power feed for the Mini/Pepwave.  I used that same wire to automatically turn on the rear camera.
Otherwise, I’d recommend adding a separate #12 or 14 circuit in parallel with the DC to DC charger cables.
Hope that helps, Geoff
lol….ok, so I like the size of the mini, but I think even if it was available I still would’ve gone with the G3. I don’t like the fact that the router is inside the mini dish, yes I know it’s weather proof, and I have a 3rd party router anyway, but just the thought of the dish with built in router put me off a little bit. It’s probably not an issue at all, just me being silly! 🤪
**Sold😞**
This could be a very good idea for my application. Could I have both connected? Both the 12V+ from starter battery and 12V+ from tow harness to power the Pepwave router/Starlink system? Or would this require a relay that would disconnect 12V+ from the starter battery when 12V+ is connected at the trailer harness. I'm thinking such relay would be required. If so and you could suggest a viable relay it would be greatly appreciated! Thanks again Geoff, for sharing your knowledge.
15 minutes ago, jd1923 said:
This could be a very good idea for my application. Could I have both connected? Both the 12V+ from starter battery and 12V+ from tow harness tIf so and you could suggest a viable relay it would be greatly appreciated! Thanks again Geoff, for sharing your knowledge.
There are battery isolators for charging, but I've never seen one that would work for your purpose of using both sources at the same time to power your Mini.  You would be essentially wiring the batteries in parallel, and it's also a no-no to mix lithium and lead acid.  I'm sure you could rig up a diode affair, but that's not very realistic.
I'd keep them separate with a "On - Off - On" toggle switch to feed the Mini from one source or the other . . . or off!  The common terminal goes to the Mini, the others to the starter battery and tow harness trailer battery respectively.   Ground to the chassis.  You can get toggle switches up to 30 amps.  A relay will work too, but overkill in this case.  Just fuse it properly.  🤙
  • 4 months later...
Going back to Geoff's original post on this thread, I did this (except for relay) and it works great but have been concerned about water penetration at the exterior socket when Starlink cable is plugged in.
I have swapped mine out for a water-resistant component custom designed and made by Tom at Platypus3DDesigns in Mesa, AZ.
Although the original socket worked great, it was not water-resistant so I asked Tom to create one that would replace the Furrion Mini TV/Satellite Inlet.
Here is the link to his component. https://www.etsy.com/listing/4349330543/starlink-mini-dc-cable-pass-through
It has 18 gauge wires attached and a magnet that holds the cap in. In addition, he adds another magnet on the side that can hold the cap when not inserted.
I asked for a modification so I could add a lanyard. Tom drilled and threaded #8x32 holes for that.
All screws and machine bolts were attached with blue Loctite.
I was able to use the original Furrion gasket. I had to drill out the hole in the fiberglass a bit larger and I wrapped some butyl sealant around the barrel upon installation.
Here is a link to the lanyards. https://www.amazon.com/dp/B0B4RXTKBH?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
To finish it off, I used a very small amount of dielectric grease on the cap seal and rubber fins on the Starlink cable end. Works great.
David P.
David & Martha from North Plains, Oregon.
2023 Elite 1 Hull 1382 "Coddiwomple" with full Truma & Lithium Pro packages.
2002 Toyota Tundra 4.7L.  DC-DC Victron Orion XS 50 amp.  Truma soft start.
ARCACOIDILINIAKYMNMOMTNENDORSDTNUTWAWIWY
