rideadeuce Posted September 20, 2024 Posted September 20, 2024 (edited) Another copy of @Snowball‘s mod just used different but almost the same components. Took a few pics. I was able to save about 2/3 of the upper front maple crossbar. Real trick since the sink is 2 in deeper was maintaining drainage grade. Had to remove metal tube securement (screwed to the back of the cabinet) and was able to reuse the 1 1/2 in ABS but may end up cutting it under road side bed to shorten a bit to get more of a grade. But seems to be draining ok… we shall see. Love the sink and faucet. SO much more useful. Just have to close up top left drawer with faceboard some how. Oh, I did shim the middle between the middle maple cabinet support and counter, the counter had small bow in it. Easily corrected, then was able to silicone the sink to the counter top. Amazon Links: Brushed SS Sink 17x19x9 18g sink, 11g sink rim https://a.co/d/ I wasn’t able to use the deep drain basket that came with it due to limited space. Grohe Bar faucet https://a.co/d/hK5IcRy Best, Mike Edited September 24, 2024 by rideadeuce 2 7 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
rideadeuce Posted September 21, 2024 Author Posted September 21, 2024 Finished the top drawer mod. Keep the wood blocks on the end, they hook into to the end connectors for soft close assembly. You do have to trim them down like the rest of the drawer to make it fit under the sink. Happy that I got to keep the drawer for small things. Turned out better than expected. Had a little helper too! 1 4 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
jd1923 Posted September 21, 2024 Posted September 21, 2024 10 minutes ago, rideadeuce said: So, who is truly the brains of the operation? 🤣 I’m thinking we give you way too much credit! GREAT upgrade, Mike. Ty 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
rideadeuce Posted September 21, 2024 Author Posted September 21, 2024 (edited) 13 hours ago, jd1923 said: So, who is truly the brains of the operation? 🤣 She is definitely smarter than her dad! LoL. This morning she was complaining about the healthy cereal and I told her that her mom and I were trying to teach her to eat healthy. I said that things with a lot of sugar can cause obesity and diabetes, etc. She grinned and said “Have you been eating a lot sugar while looking at my belly!?” Edited September 21, 2024 by rideadeuce 4 1 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Moderators SeaDawg Posted September 21, 2024 Moderators Posted September 21, 2024 So, lucky you! Two great young assistant engineers. Your Ollie is full of great smiles! Great mod. Great look. 4 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
rideadeuce Posted September 21, 2024 Author Posted September 21, 2024 (edited) In retrospect, the kitchen sink is one of the only areas where Oliver did not do a great job of designing something that worked well. The OEM sink is too shallow and shaped more like a bowl. The OEM full size kitchen faucet had a reach of 8-9 (should have been 7-8in to spray in the middle ) which caused it to splash water everywhere unless you pulled down on the spray head and let it dangle. The upgrade solves all that and most importantly matches the faucet to the sink so they work together well. Plus, I like the more modern design. Mods are so much fun. Especially when so many members lead the way. Just curious, does anyone know what happened to @Snowball ? Oh, I forgot to mention for anyone doing this mod and it necessitates removing part of the cabinetry. Cover the soft close mechanisms, I had a hell of a time cleaning out all the saw dust. Lots of small moving parts make that work smoothly. Edited September 21, 2024 by rideadeuce 3 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
