Finally, going to have an oven. I checked the hotspots of the Toshiba MW/oven and the only place it got warm was the back and on top. So I decided to take the plunge with an abundance of  caution while using it because I really miss: warm cookies, birthday cake, biscuits, pizza, etc.
I did line the cabinet with 1 mm adhesive backed fiberglass high heat barrier. Luckily with a little modification I was able to use the old MW SS trim kit. So plug and play essentially. Again, I will be measuring the cabinet temperatures while using. I think the most likely problem may be that the unit gets too hot or prematurely stops working. Although every looks good so far, nothing abnormal or high temps
The highest wattage pulled that I saw while using the convection oven and AC on high was around 2800 watts. Will try to only use one at a time though.
Links:
Heat shield  https://a.co/d/14NmCvX
Toshiba  https://a.co/d/gGyB2Gc
Best,
Mike
IMG_0893.thumb.jpg.87c634843fadc8939b8f016f53e22b42.jpgIMG_0894.thumb.jpg.4792e231ec410afd40f359701708085c.jpgIMG_0895.thumb.jpg.5879731272c6b5f31e85df3b4b22c4b0.jpgIMG_0896.thumb.jpg.7303d26f49dd664700c65ca84886dcc0.jpgIMG_0898.thumb.jpg.6a3aac8447213513f0cb78fabb894d36.jpgIMG_0902.thumb.jpg.111509730d1d2ce5f0cdc0754a3ae610.jpgIMG_0905.thumb.jpg.089c20b9ae779e9cbd746a3fc8e3ca09.jpgIMG_0907.thumb.jpg.b8e2d85a95105c9d176db6bce55db377.jpgIMG_0909.thumb.jpg.bd49aacb172a864a29e41c840324b863.jpgIMG_0910.thumb.jpg.89656e4ffc1cb2bd3cdc9c5deaa532b8.jpg
Edited by rideadeuce
  • Love 2
-  Mike  Brentwood, TN  -  2018 Elite II  -  Spirit of Adventure Hull #308 -  2016 Toyota Tundra Limited 5.7L  Class IV hitch with 12k lb coupler, Dobinsons HD 2in Leaf springs, Timbren bump stops, Eibach Pro Truck Stage 2R, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Good to hear from you Mike. Another great upgrade in your list of many. Good work and I especially like your thin insulation fabric. Thanks
You may eventually want to add a vent or two. Our 2008 had a vent to the sink side.
Even though we no longer have a microwave,  I still like the vent. When parked, I prop the cabinet door open a bit.
Nice install. Wishing you the best.toshiba makes some great products.
Edited by SeaDawg
I added these both sides.
