Dennis and Melissa Posted October 26 Posted October 26 I have 2 lithionics 320Ah batteries with solar. They were allowed to sit in the shade for about 2 months. When I returned today, the batteries were so low the fan for the composting toilet was not running. That's what I expected. But I'm surprised to see my VictronConnect app report the batteries at 100%. I tried resetting the BMV controller (press setup and select at same time for 3 seconds), but that doesn't seem to do anything. I'm currently recharging the batteries slowly (solar + household current). Any thoughts? 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
Dennis and Melissa Posted October 26 Author Posted October 26 FWIW, the LI3 Battery app reports each of the batteries at 24% now. 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
Dennis and Melissa Posted October 26 Author Posted October 26 I just watched Victron's video for the BMV-712. It says the batteries need to be fully charged twice a month to allow the monitor to sync. So, I guess I just charge the things and hope it clears up 🤪 4 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
jd1923 Posted October 27 Posted October 27 4 hours ago, Dennis and Melissa said: But I'm surprised to see my VictronConnect app report the batteries at 100%. We have to get to the bottom of this, as I have also found the Victron app or the Victron SmartShunt to be unreliable. i do not have the OTT installed Lithionics but instead self-installed 600AH Epoch batteries. We also have an Epoch app that regularly shows a lower SOC reading. Note the two pics. The Victron app states we have 54% SOC but it also states AH consumed at -321.7A. This is more than half of our 600 AH which calculates to 46% SOC. The Epoch app (y’all have a Lithionics app) appears to be more accurate showing 43% SOC. Since the battery app is a more conservative reading and appears more accurate, we count on this number when traveling! Hope this helps! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Rivernerd Posted October 27 Posted October 27 19 hours ago, Dennis and Melissa said: But I'm surprised to see my VictronConnect app report the batteries at 100%. This report is consistent with my experience as well. I have found the LIthionics app provides much more reliable State of Charge (SOC) readings. I have also found that: (1) fully recharging my Lithionics batteries, after nearly full discharge (down to 24% SOC) then (2) leaving the charging source connected for a couple more days enables the batteries to rebalance, and the Victron Connect app to read the same as the Lithionics app. 2 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Dennis and Melissa Posted October 28 Author Posted October 28 After recharging, everything seems to be back to normal. No worries. 😎 I think I have learned: "the batteries need to be fully charged twice a month to allow the monitor to sync". 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
jd1923 Posted October 28 Posted October 28 22 hours ago, Rivernerd said: leaving the charging source connected for a couple more days enables the batteries to rebalance, and the Victron Connect app to read the same as the Lithionics app. But then the Victron app will error again as SOC decreases again reading higher then actual, in my experience. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Rolind Posted October 28 Posted October 28 I have found that the built in battery heaters in my lithionic batteries will also a cause a difference between SOC readings on my Victron Shunt and my Lithionics app. Power use for the internal battery heaters does not register on the Victron. Not sure if it has been cold enough at your location to trigger the heaters. 2 1 Robert and Cheryl, Louisville, KY, Legacy Elite II Hull #1390 Oliphino, TV F250 Tremor
Rivernerd Posted October 28 Posted October 28 4 hours ago, Rolind said: Not sure if it has been cold enough at your location to trigger the heaters. Thanks for reminding me to turn on the battery heater under my three Lithionics batteries for the winter! Our local forecast is for temps well below freezing starting tomorrow night. 2 1 3 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
