Guest TxMN2020
I use a 12v milwaukee grease gum with lock n lube attached to flexible hose. We plan to pickupy our Oliver this month, jest trying to get a few Service temp together. Will this set up work for Oliverx lubrication needs?
i mosty use Lucas Red and Tacky around The farm
Many people use the lock n lube.
I'm sure you are looking forward to picking up your new Ollie soon. Congratulations.
I'm sure you'll get comments on the gun from others who've used it.
Oliver uses Mystik Red grease at the factory.  If Lucas Red "N" Tacky is compatible with Mystik, you should be "good to go".
I am also a Lock N Lube fan.
  • 3 weeks later...
Ditto: Lock N Lube, Mystic in my axle zerks and CV-2 on the bearings.  That said, when I run out of CV-2 (In about 8 years) I'll go with the Dexter Mobile Synthetic bearing grease.  It is specifically called out in the EZ Flex installation procedure that I posted earlier today.
