Hull #527 ready for carrying bikes! After the factory tour, I wanted a bike rack receiver hitch but NOT the one they sold. At the time there was not a safe option for an 2” receiver.  After buying a used LE II, I decided to look for a good welder. I am happier than ever with the way this turned out and at a fraction of the price.
  • 1 month later...
Weight rating? The hitch will handle a lot, question is the bumper itself. The stock one is rated at 100 lbs which won’t work for me as my Kuat Piston Pro is 63 lbs by itself and I have heavy eBikes.
Ultiumately not a problem, I’ll keep the bikes in the truck bed and swap the bike rack for the rear shelf storage. Wouldn’t hurt to have the option though.
Sierra EV AT4 2026 (max range 500 mile pack)
Actually it was upgraded to 150lbs a few years ago.
**Sold😞**
On 4/3/2025 at 9:11 PM, dmtaylor2 said:
Steel, but square tube. Couldn’t be happier.
How did you address galvanic corrosion?
SIR?
1 hour ago, topgun2 said:
SIR?
Dissimilar metal corrosion. Aluminum bumper and steel bolts, frame etc.
OK then, how about MRS.?😁
