Galway Girl Posted May 2, 2025 Posted May 2, 2025 (edited) It appears that both FRONT brakes are not energizing. Based on other posts, I'm assuming I should rewire to avoid using the lines that run through the front tube. If that doesn't work what's the next step? I saw another post about the wires all being mashed together and soldered under the street side bed before they head out thru hull. Tips? Craig Edited May 2, 2025 by Galway Girl Solved 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
jd1923 Posted May 2, 2025 Posted May 2, 2025 22 minutes ago, Galway Girl said: It appears that both FRONT brakes are not energizing. Given only FRONT with rear trailer brakes working, I cannot see you'd have open wires inside your hull. I would get under your Oliver and check for any visible damage to the wires. Check for voltage there, with either TV connected and truck brake depressed, or by connecting 12V at the harness, B+ to blue/brake wire) and B- to white/ground (if I'm remembering the colors correctly). If you have voltage there (which you should have given the rears work) then you have confirmed wiring internal to the hull is good. Then check for voltage in-between each brake drum. Could be an open ground to the front brakes too. You could also have a burnt magnet or wire harness internal to one of the front drums, so next step is to get inside and test for voltage and ground inside each front drum. While you're in there set your self-adjusters to get the brake shoes nice and close! 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galway Girl Posted May 2, 2025 Author Posted May 2, 2025 (edited) Problem Solved: Bad Crimps on New 3 way crimp connectors I had bought new brake and hubs for the trailer and had the installation done at the same place doing our Truma Recall. I looked more closely and used a check light to trace power to the new 3way crimp connectors (for the new brake assemblies.) They didn't look fully seated on the fronts the same as the rear. Squeezed them with a pair of channel locks and voila, now the front brakes on both sides are engaging. Since I was under the trailer I went around and manually adjusted all 4 brakes to the same resistance. Next I'll be burnishing in the brakes as we begin our next trip. Craig - Hull 505 - Galway Girl Edited May 3, 2025 by Galway Girl 8 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
jd1923 Posted May 2, 2025 Posted May 2, 2025 1 hour ago, Galway Girl said: I had bought new brake and hubs for the trailer Yep, always look at the most recent service for a current issue. Good you found it quickly! 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galway Girl Posted May 11, 2025 Author Posted May 11, 2025 linked to the after story. See embedded fail note. 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Geronimo John Posted May 11, 2025 Posted May 11, 2025 On 5/2/2025 at 1:28 PM, jd1923 said: Check for voltage there, with either TV connected and truck brake depressed, or by connecting 12V at the harness, B+ to blue/brake wire) and B- to white/ground (if I'm remembering the colors correctly). Voltage is not ALWAYS a sure bet. When not under load, a wire may show full voltage, but not have the ability to pass the current to meet the need. My preference, which is a lot easire to check on drum brakes, is to check the amperage going to each drum. Having a clamp on amp meter is my first go to tool. Per dexter, the stock OEM drum magnets should show 3.2 to 4 amps each. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
