Olive2Roam Posted May 8, 2025 Posted May 8, 2025 Hey folks, Here's the skinny. 2024, LE I with Truma AC, Furnace and on demand HW heater. Until today, my control panel was recognizing the furnace and the water heater, but not the AC. I did a reset per the Truma manufacturer's manual, and now, the control panel sees the furnace AND the AC, but NOT the hot water heater. Switch is on on the HW heater and we are on shore power here at home (120). Looks like my best option at the moment is a trip back to the mother ship (scheduled for Monday) unless I can sort this out. Any thoughts? P.S. Enjoyed meeting many of you at the Lake Guntersville rally! 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
Olive2Roam Posted May 8, 2025 Author Posted May 8, 2025 I should have mentioned that the good news is that the hot water is working just fine even though it is not connected to the control panel. So not the end of the world, but would like to get it connected. By the way, I spoke with both Truma and Oliver service about it and we were unable to come up with a solution. 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
Moderators topgun2 Posted May 8, 2025 Moderators Posted May 8, 2025 Bob & Barb - I don't really know anything about Truma products - but - If it were mine, I'd unplug and re-plug any of the "control" wiring that you can find. Next, I would turn everything off for at least a minute so that any "memory" functions have a chance to clear (note by "turn off" I mean that these units should have no source of power. So, I would disconnect from shore power and make sure that all breakers are off). Finally, I'd turn things back on and (once again) do the Reset as per the Truma instructions. Hopefully this would "cure" any electron malfunction that may be present. Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Olive2Roam Posted May 8, 2025 Author Posted May 8, 2025 Good suggestion, Bill. I will give that a shot and report back tomorrow. Bob 1 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
Olive2Roam Posted July 12, 2025 Author Posted July 12, 2025 Just to put a bow on this one, we ended up having the panel replaced at the factory. That did the trick. Thanks again! 5 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
Patriot Posted July 12, 2025 Posted July 12, 2025 10 minutes ago, Olive2Roam said: Just to put a bow on this one, we ended up having the panel replaced at the factory. That did the trick. Thanks again! Thanks for posting your final fix/outcome. This really helps other owners should they experience a similar issue. Safe Travels! 5 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
