GlacierGirl Posted May 18, 2025 Author Posted May 18, 2025 1 minute ago, Jason Foster said: Lots of good people on here. INDEED!!! Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
Rivernerd Posted May 18, 2025 Posted May 18, 2025 25 minutes ago, GlacierGirl said: My husband thinks the steel on the 1UP shank will be too hard to file down by hand. The 1UP shank fits fine in our tow vehicle’s 2” receiver. The "safe harbor" would be to file down the steel 1UP shank, to avoid reducing the strength of the (much softer) aluminum 2" receiver. As it seems you do not already own a grinder with a metal grinding wheel, I recommend you buy an inexpensive 4-1/2" grinder from Harbor Freight ($15), along with a steel grinding wheel ($2). That $17 investment will make quick work of grinding down the leading edge of the steel 1UP shank. Wear eye protection! https://www.harborfreight.com/43-amp-4-12-in-angle-grinder-with-slide-switch-58089.html?utm_source=google&utm_medium=cpc&utm_campaign=22297023987&campaignid=22297023987&utm_content=174581963486&adsetid=174581963486&product=58089&store=54&gad_source=1&gad_campaignid=22297023987&gbraid=0AAAAADAHb4fYAJW562_ET-7xFgrqI0OTz&gclid=CjwKCAjw56DBBhAkEiwAaFsG-s7clZOjXr5HmLObHpLJU78M9ai56THL1WHHf7T8vdcqRRwuMLx5rBoCoVEQAvD_BwE https://www.harborfreight.com/4-12-in-24-grit-metal-grinding-wheel-64025.html Good luck! 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2026 Ford F350 Crew Cab with 7.3L gas engine
GlacierGirl Posted May 18, 2025 Author Posted May 18, 2025 13 minutes ago, Rivernerd said: The "safe harbor" would be to file down the steel 1UP shank, to avoid reducing the strength of the (much softer) aluminum 2" receiver. As it seems you do not already own a grinder with a metal grinding wheel, I recommend you buy an inexpensive 4-1/2" grinder from Harbor Freight ($15), along with a steel grinding wheel ($2). That $17 investment will make quick work of grinding down the leading edge of the steel 1UP shank. Wear eye protection! Thank you, @Rivernerd! That’s the direction my husband would like to go. We appreciate the links.😊 Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
Jason Foster Posted May 18, 2025 Posted May 18, 2025 7 minutes ago, GlacierGirl said: Thank you, @Rivernerd! That’s the direction my husband would like to go. We appreciate the links.😊 The flip side to this approach is 1) assuming the aluminum reciever is sturdy enough as it looks like it was designed for additional interior pieces. 2) grinding the bike rack hitch to fit will make it useful only for your current Oliver and will be way too loose in a standard hitch receiver. If you were to grind down the hitch to fit and it later broke the aluminum receiver, a replacement receiver would be too big requiring you to get a new hitch from 1up. There are positives and negatives to both routes. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
GlacierGirl Posted May 18, 2025 Author Posted May 18, 2025 5 minutes ago, Jason Foster said: The flip side to this approach is 1) assuming the aluminum reciever is sturdy enough as it looks like it was designed for additional interior pieces. 2) grinding the bike rack hitch to fit will make it useful only for your current Oliver and will be way too loose in a standard hitch receiver. If you were to grind down the hitch to fit and it later broke the aluminum receiver, a replacement receiver would be too big requiring you to get a new hitch from 1up. There are positives and negatives to both routes. Very good points. This is why I asked y'all on the forums! 1 Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
GlacierGirl Posted June 27, 2025 Author Posted June 27, 2025 On 5/14/2025 at 5:00 PM, Steve Morris said: Barb, in July 2023 I replaced the OEM receiver with the Reese model linked below. It required new holes drilled in the crossmember, but being aluminum, that was easy. I also went larger, using 1/2” stainless fasteners rather than the 3/8” U-bolt. @Steve Morris, argh! I made the mistake of having my husband install the Reese receiver backwards(?) on our back bumper. In other words, the wider & higher “lip” around the receiver is closest to our spare tire. Is this a problem? It would be an easy fix if we could simply turn it around, but with the original Oliver receiver holes drilled in the bumper, and now the “backward” Reese receiver holes, I worry about rotating and moving the Reese receiver off-center and adding more holes. What is your opinion? Thank you! Barb 1 Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
GlacierGirl Posted July 7, 2025 Author Posted July 7, 2025 @Steve Morris, I wonder if you saw my question in the above post? Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
Steve Morris Posted July 7, 2025 Posted July 7, 2025 12 minutes ago, GlacierGirl said: @Steve Morris, I wonder if you saw my question in the above post? No, I had not read that question earlier. It should function fine either direction. The only negative would be if the weld that holds the tube to the plate were to fail, the collar wouldn’t capture the cross pin, allowing the rack to become lost. But I’m pretty confident that the Reese receiver is far better than the no-name options available, and have not seen a review with a weld failure. Ours has been fine for over 12,000 miles now. 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
GlacierGirl Posted July 7, 2025 Author Posted July 7, 2025 @Steve Morris, oh, thank you so much! Your knowledge about such things is helpful and your answer is comforting. I appreciate your input! Barb 1 Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia
