rich.dev Posted May 14, 2025 Posted May 14, 2025 If you’re not connected to shore power the AC will not show up on the cp plus screen unless you turn the inverter on, with the inverter on it will show the “heater” and “AC” option. 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
T-Oliver Posted May 14, 2025 Author Posted May 14, 2025 Shore power and water heater shows, no A/C on screen. A/C works with remote. Data cable ? Hard reset ?
rich.dev Posted May 14, 2025 Posted May 14, 2025 This is what mine looks like, we’re not on shore power and inverter on. IMG_1168.mov **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
ScottRicki Posted August 30, 2025 Posted August 30, 2025 Our CPPlus also lost connection to AC. Tracked the issue to a RJ45 coupler located inside above the air diffuser. They used it to connect the short cable from the rooftop to a long cable to CPPlus. The cable and coupler and wires needed secured to eliminate movement at the coupler. I used electrical tape around the coupler and then silver tape to secure the wire and coupler. To remove diffuser pull off both side intakes where filters are and remove six bolts and the connection to IR receiver. I believe there is another data cable plug connection in the upper unit but fortunately I didn’t have to go to the roof Scott&Ricki 2017 Legacy Elite II Twin, Hull 225, The Bus 2007 Tundra Prev: 2003 Casita, 2009 Weekend Warrior
FloraFauna Posted August 30, 2025 Posted August 30, 2025 Yes, I had this glitch when my trailer was new. While its true that you have to have the inverter on when not connected to shore power, this happened to me with the inverter on or off (and not connected to shore power). Could only turn on the AC via the remote. The wiring to my CPPlus was fine. I took it to a Truma authorized service center and the AC had been wired with some wires reversed at the AC unit itself. After this fix it reappeared and worked fine at the CPPlus. 1 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
FloraFauna Posted July 31 Posted July 31 (edited) Did this get resolved? On my last trip my ac disappeared from the cp plus panel for a couple of days and then eventually reappeared with no apparent action on my part. I am suspecting I have a flaky RJ45 coupler somewhere? Inverter was on both times and i was in some desparate heat and humidity where i had to run off battery power for an hour or so. Fortunately the remote controlled the aventa just fine. Running the aventa off battery power at the beginning of the trip is not a real winner. @jd1923 has me thinking about the Furrion Chill. Edited July 31 by FloraFauna 1 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
