2024 Elite II #1541
Good morning, Oliver owners. I’m reaching out to see if anyone has experienced something similar or might have an idea what caused the “beeping” issue we dealt with last night.
Setup:
  • Lithium Pro Package – 390AH Lithionics batteries
  • 3000W Pro Inverter
  • Batteries fully charged
  • Connected to 30A shore power
  • Progressive external surge protector plus the internal Oliver surge protection
Around 11:30 PM, we woke up to a beeping sound but couldn’t immediately determine where it was coming from. We checked the CO2 detector, MaxxAir fan, and propane monitor — all appeared normal.
The beeping would stop for 10–15 minutes and then start again. During one of the episodes, the Xantrex wall control showed a red light and was also beeping. Unfortunately, I didn’t catch the exact readings before the light went out and the beeping stopped again.
The Xantrex app on my phone briefly displayed an alert, but it disappeared within seconds. I think it may have said something about high battery voltage, but I’m not certain.
Here’s what I tried:
  1. Disconnected the external surge protector at the pedestal, thinking it might be the issue. Same results.
  2. Switched from the 30A connection to the 50A adapter connection. Beeping continued.
  3. Tried turning the batteries off, at which point I noticed the blue lights on the batteries were blinking.
  4. After that, the trailer power started cycling — lights, AC, and radio turning on and off intermittently??
I had assumed the trailer could still run directly from shore power with the batteries off, but that didn’t seem to be the case.
Finally, I turned the batteries back on, left the trailer plugged into 50A shore power, and since then everything has been operating normally with no additional beeping.
I’ll also post this on the Oliver forum for those not on Facebook, and I may give Oliver Service a call today.
Any thoughts, similar experiences, or troubleshooting suggestions would be greatly appreciated. Thanks in advance.
I vaguely remember needing to reset a parameter within the settings of the Xantrex to avoid that problem.
The battteries blink When charging so that’s normal.
I n our case the LOW Battery Cutoff Voltage setting was not set properly after an update to our system....and it would do the beeping thing.   The settings are easily changed in a data table on your xantrex phone app.
Your settings would be the column to the left of the red column below:   LCBO Voltage can be set from 11.5-12.1
FURTHER INFO:
Here's some data from the web:
A beeping sound from a Xantrex inverter charger is an audible alarm indicating low battery voltage, an electrical overload, or internal overheating. The system uses the beep to protect the internal components and the connected battery bank from permanent damage. [1, 2, 3]
Most Common Causes
  • Low Battery Voltage: The battery bank has dropped below the low-voltage cutoff threshold (typically around 10.5V for 12V systems). This can happen if the batteries are drained, a battery cell is dead, or the charger is disabled.
  • AC Output Overload: The continuous power draw from connected appliances exceeds the total wattage capacity of your Xantrex unit. This triggers a warning beep before the system shuts down to protect its circuits.
  • Overheating (Thermal Shutdown): Poor ventilation, blocked cooling fans, high ambient air temperatures, or heavy prolonged loads can cause internal temperatures to spike.
  • High Battery Voltage: An external charging source like an un-regulated solar controller or high-output vehicle alternator is pushing voltage above the upper safety limit (usually >15.5V).
  • Bad Cable Connections: Loose, corroded, or undersized DC cables cause a sudden voltage drop across the connection terminals under load. The inverter reads this localized drop as a dead battery and triggers an alarm. [1, 2, 3, 4, 5, 6, 7, 8, 9, 10]
Troubleshooting Action Steps
  1. Check the Digital Display: Look for error codes like E01/E05 (Low Voltage), E03/E06(Overload), or E04/E07 (Over-temperature) to pinpoint the exact failure type.
  2. Verify Voltage with a Multimeter: Test direct DC current across the battery terminals. If it reads under 12V, plug into shore power or run a generator to engage the battery charger.
  3. Shed Electrical Loads: Unplug high-draw appliances like microwaves, coffee makers, or hair dryers to see if the beeping stops.
  4. Inspect Physical Connections: Tighten all cable terminals. Clean off any green or white corrosion crust with a wire brush. Ensure the cooling fan spin freely and the air vents are completely clear.
  5. Perform a Hard Reset: Turn off the unit. Completely disconnect all sources of AC shore power and DC battery power for 5 to 10 minutes to reboot the internal microprocessors. [1, 2, 3, 4, 5, 6, 7, 8, 10, 11]
If you would like to pinpoint the issue further, please share:
  • The exact model number of your Xantrex unit (e.g., Freedom HF, XC Pro, XPower).
  • Any fault codes or lights flashing on the display screen.
  • Whether you are currently plugged into shore power or running on battery power. [1, 2, 3, 4, 5, 6]
Edited by Galway Girl
