Geronimo John Posted July 18 Posted July 18 On 7/16/2026 at 6:49 PM, SeaDawg said: 5k buys a lot of battery power and portable solar. An awning has to be brought in in windy conditions. Pretty prevalent in many parts of the west. I'd skip it. We use the original awning a lot. Sometimes only a foot or two over the door. Never been tempted to get a second awning, though. I totally agree with SeaDawg. Many owners have had a gust of wind take out an awning. Having $5K invested in one would worry me a lot. We have a DC to DC, sadly the older 30 amp one. Best investment ever for those covering a lot of miles. Front gas port and plug in can be handy as well if they are not standard. One item that I really like is our 16" tires. OTT changing to 15's IMO was a rare step in the wrong direction. If you are going to be in the mountains a lot, get the 5200 pound dexter axles for the larger brakes. I, and others, don't recommend the larger propane tanks. When you get older their weight becomes prohibitive. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Galileo Posted July 18 Posted July 18 On 7/17/2026 at 11:56 AM, jd1923 said: Of course we would not be able to negotiate such a bare Oliver, but it would be a great canvas to paint my own design and build. Why not? As they say “everything is for sale - the only question is the price.” More than once I’ve thought that “the bare bones are great, it’s the accessories and layout of some of the utilities that have issues.” 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted July 18 Posted July 18 57 minutes ago, Geronimo John said: We have a DC to DC, sadly the older 30 amp one. Best investment ever for those covering a lot of miles. Front gas port and plug in can be handy as well if they are not standard. GJ added comments are great! Too he added his DC-D charger just before Victron came out with the smaller and more efficient Orion 50A charger. Either way, OTT would only install the Oliver half of the installation and last time they offered a sale, it included the older 30A version. We use front LP port everyday camping. We have a 12 ft extension LP hose with quick connects and a Y-coupler on the other end. Connect our fire ring and grill at the same time. You need to remove the regulators from your appliances since the LP on board is already regulator to low pressure. Too bad OTT installs the rear connection inside of the sewer compartment, where you must drop the bumper to use it. I would use it on rare occasion if it was accessible like the front but never have. Tried to remove it but the underbelly LP lines are not easy to access. Many carry an extra tank for their grill, and you should have an extra tank if you go with two 20# tanks. Also, if you must use a generator the front shore power outlet can be helpful. Better to order or modify a new trailer with enough electric to avoid this (we run A/C for days on battery with a variable-speed A/C). If you go without the second outlet you won't need the PD5100 Automatic Transfer Relay. These are known to fail. I replaced one in a class-A RV and later a class-C years ago. I bypassed the one in our Oliver since we weren't using it and I preferred a direct run. My picture shows the PD5100 still installed if needed someday and right now it's only holding up our LevelMatePRO, another very useful upgrade we wouldn't live without. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galileo Posted July 18 Posted July 18 On 7/8/2026 at 7:47 PM, larcat said: We'll catch flack, but we'll be using our 3rd gen Tacoma as a TV for a good while. No plans for mountains, and when we do we'll get a full-size. We live in SETX, and it is _flat_ here. We initially towed with our 2021 GMC Canyon Denali with the 2.8 liter Duramax diesel - handled the Oliver with zero issues. Only traded it for the Sierra 2500 Denali with the 3.0 liter Duramax because I wanted to trade it before it got too many miles. We were based in NE Texas - which as also pretty flat - but we had no problems towing the Ollie over the continental divide several times and negotiated plenty of mountains. From Florida to PEI to Yellowstone and NM. The diesel gave us exhaust braking, so at 80,000 miles our TV brakes looked near new. Your Tacoma has more HP - but the Diesel has more torque - and it comes it at 2,000RPM - so plenty of guts to get up to speed without the engine screaming. We also enjoyed stellar mileage - 20mpg towing was pretty typical on flat interstates. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted July 18 Posted July 18 3 minutes ago, Galileo said: Your Tacoma has more HP - but the Diesel has more torque - and it comes it at 2,000RPM - so plenty of guts to get up to speed without the engine screaming. We also enjoyed stellar mileage - 20mpg towing was pretty typical on flat interstates. And you mentioned an exhaust brake which makes a huge difference! I added a Pacbrake exhaust brake on our TV and love it, use it almost always since it's safer to slow as soon as you lift your foot off the pedal, in mountains of course but also on busy highways. We get 13 MPG regularly towing in the Mountains! Never have gone long enough on flat Interstates to know the number. If we do make it to The Rally, I'll have 1700 miles mostly on I-40 to measure this. I'm thinking 15 MPG will be the number. Yes, torque is the criteria for towing, HP not so much. But the REAL issue with smaller trucks is the footprint, width and wheelbase. Our truck is a solid TV since it's full width and an extra cab with long bed. And with 2WD the center of gravity is much lower (which nobody wants but me, but towing weight is on the rear wheels). All of this adds to stability. After a quick test drive, I could not imagine towing with our GX470 and it's not for the 470, but for the short wheelbase. The length of the 23' trailer and a SWB truck is the tail waggin' the dog! 🤣 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galileo Posted July 18 Posted July 18 (edited) 17 minutes ago, jd1923 said: And with 2WD the center of gravity is much lower (which nobody wants but me, but towing weight is on the rear wheels). All of this adds to stability. After a quick test drive, I could not imagine towing with our GX470 and it's not for the 470, but for the short wheelbase. The length of the 23' trailer and a SWB truck is the tail waggin' the dog! 🤣 I stick to the lowest-slung truck possible. The Denali trim level on the 2021 Canyon is pretty close to the ground - just as low as the 2wd. Same with the Sierra. We stay off of the “4wd, high ground clearance” trails. That, and we don’t need a ladder to get in and out. No AT4’s for us. I’ve only used the 4wd once on the Canyon - when I inadvertently pulled onto a loose sand “road” and shifted to 4wd as a precaution. I think I used it once on snowy roads in Chicago without the trailer. Same with the Sierra. I would have chosen 2wd as well - but the Canyon was in the tail end of COVID when I was lucky to find anything. With the Denali’s - people have to do a double-take to even realize it’s a diesel. We can sneak in and out of campgrounds without waking up the neighbors. Granted, you definitely know you have a 7,000 trailer behind you with the “smaller”, lighter trucks, but maneuverability and parking are pretty high up on our priority list. The Canyon was easy to park and get through narrow streets. (We like NOLA) It was also a lot lower than the Sierra - which makes for a lot better being able to see where the corners of the truck are. I can’t imagine backing up without the cameras all around - seeing over the hood or bed of a full size pickup is an act of faith. Edited July 18 by Galileo More stuff 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted July 19 Posted July 19 (edited) 6 hours ago, Galileo said: That, and we don’t need a ladder to get in and out. No AT4’s for us. Yeah, I had the pleasure of driving a full-size 4WD GMC diesel TV last week. Beautiful truck! A climb up to the driver's seat like a snug cockpit up there. Leather luxury with the dashboard all lit up, I felt somewhat disconnected from the road. The view out seemed narrow, even with the huge, self-folding mirrors. My old truck, I can get my old butt up into the seat np without using the step, old-school dash, very connected at ground level. We all get used to what we have. Driving 4WD trucks where you don't need 4WD has gotten old for me. I've owned work trucks and farm trucks, all but one 2WD. 4WD trucks have steering and suspension maintenance and longevity issues that 2WD trucks do not have. On the upside, they make high-performance parts for 4WD trucks, but not for 2WD trucks. They are literally a pain to work on (it's only me doing the work). When we replaced the starter motor on my son's '97 T100, I had to remove a skid plate and the driveshaft to the front diff! If it was 2WD there would be nothing but room down there. We had a thread a couple years ago and there was NOT ONE forum member that said they would tow without their 4WD. I tow the Oliver up CRAZY ROCKY STEEP dirt roads out here in 2WD, np. The weight of the trailer on the rear wheels keeps them from spinning. We generally don't have mud in Arizona but be careful of sand when crossing a wash bottom. If I would have to tow with anything less than a 2500 diesel, it would be a midsize diesel, like yours, or the Nissan with the Cummins! I would not be able to sleep at night if I knew I had to tow with much less. We now tow much more smoothly with Alcan Springs, now that the top-heavy Oliver doesn't sway left to right as the hull porpoises front and back, not anymore. Anybody towing with a half-ton truck or less, please upgrade your leaf springs and use the WDH. Fortunately, the OP is buying an Apex with Alcan Springs! 😎 Edited July 19 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galileo Posted July 19 Posted July 19 (edited) 13 hours ago, jd1923 said: 4WD trucks have steering and suspension maintenance and longevity issues that 2WD trucks do not have. That was a concern - as was the extra drag/friction from spinning those parts even when you’re in 2wd mode. Too many CV joints IMHO. That said, the Canyon was the only truck available for us with the engine I wanted at the time we were taking deliver of the Oliver - so I literally bought it sight-unseen over the phone with a credit card. It was a great truck, and we traded it before wear and tear became an issue. 13 hours ago, jd1923 said: We had a thread a couple years ago and there was NOT ONE forum member that said they would tow without their 4WD. We all have our preferences, biases, and red lines. As I mentioned - I’ve only used the 4wd once while towing - and that was strictly precautionary. It WAS handy while driving on snow while not towing - but I’d driven RWD cars on snow my whole life with no problem. 13 hours ago, jd1923 said: They are literally a pain to work on (it's only me doing the work). When we replaced the starter motor on my son's '97 T100, I had to remove a skid plate and the driveshaft to the front diff! If it was 2WD there would be nothing but room down there. Though I carry enough tools to do most of my own work, I’ve given it up. With the new, in-warranty trucks, I leave that to the dealer. Even oil changes and tire rotation. I know people love to hate dealers, but even independent shops charge an arm and a leg now, so I go with the folks who know my vehicle best. My TPMS display has been showing a tire a bit low, so I checked with my “high accuracy” digital gauge and found that most likely the sensor was off. I kept an eye on it checking every so often. Finally I saw an actual decrease in air pressure - slight - so I aired it up and checked even more vigilantly. It took two or three days, but I lost a PSI or two. At that point, I confessed to having a leak. I dragged out my floor jack (yes, floor jack - A/C “racing” jack) and pulled the tire off. After picking peck of gravel out of the treads - I found a -tiny- nail in the tread. I marked it, put the spare on, and nearly gave myself a hernia hoisting that punctured tire into the bed of the truck. I’d never played with tires on full sized pickups before. The mounted 275/60R20 Tire on the cast aluminum wheel weighs in at about 80# - like a sack of cement. Long story short - I’m DONE even rotating my own tires. I can’t even imagine changing a flat on the side of the road - in the rain - in traffic - with factory screw jack. Sure, I’d do it myself before I’d call AAA (and wait four hours) but I’ll not volunteer for that duty anymore. 13 hours ago, jd1923 said: We now tow much more smoothly with Alcan Springs, now that the top-heavy Oliver doesn't sway left to right as the hull porpoises front and back, not anymore. Anybody towing with a half-ton truck or less, please upgrade your leaf springs and use the WDH. Maybe it’s my sedate driving style, keeping things slow and gentle, or just picking good roads, but I don’t see a lot of sway or top-heaviness. We have the Andersen “no-sway” hitch, but standard suspension on the 2022 Oliver. I just make sure I slow down well before I hit the exit ramps from the highway. I do my own lubrication and inspecting of the suspension, but I’ll have a trailer shop give it a once-over this winter. (In Texas, there’s a trailer shop every 5 miles or so.) If it looks like it needs help, I’ll consider the upgrade. Edited July 19 by Galileo Fat fingers 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderator+ ScubaRx Posted July 19 Moderator+ Posted July 19 23 hours ago, Galileo said: Why not? Because they wouldn't build one like that. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Galileo Posted July 20 Posted July 20 18 hours ago, ScubaRx said: Because they wouldn't build one like that. As I suggested - everything is negotiable. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted July 20 Posted July 20 4 hours ago, Galileo said: As I suggested - everything is negotiable. @ScubaRx Steve is right on this one (as usual), and NO, not everything is negotiable. I've been low-balled on so many items I've listed used 4-sale and I walk away, NOT negotiating with them. I don't respond to the questions, what's the lowest you'll go? I'll go, but not with that guy. Knowing when to walk is half the "Art of the Deal." I would have loved the stripped-down Oliver, because I'm an engineer, auto mechanic and restorer at heart. I was going to modify everything to my liking anyway and it would have been cleaner without having to remove the old, patch fiberglass, etc. OTT offering a naked Oliver? Dumb business model. Their product, their intellectual property is the Oliver as a "special package." If they sold a bare-bones model they would lose most of their margin. They would have legal and warranty issues, the list goes on. Ford sells the E450 chassis and 100 RV manufactures build on it. That's not OTT! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted July 20 Moderators Posted July 20 5 hours ago, Galileo said: As I suggested - everything is negotiable. I also agree with Steve on this. Oliver used to be flexible with build modifications. Even in 2015 when we ordered and our trailer was started it was possible to negotiate modifications to their normal build. A year or so later that stopped and they started standardizing their assembly line, then bundled individual options into packages, etc., even to the point now where there is a standard graphics color. It makes economic sense for them. Best bet for a stripped down model is to do what John did and get a “vintage” trailer and take out all the worn out, outdated things and start over. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Douglas Rink Posted July 21 Posted July 21 Too cool, looks like we’re both getting Apex’s in October then and as an “Honorary Texan” from my time stationed there will share a Big Texas smile with ya. Cheers! 1
larcat Posted July 22 Author Posted July 22 9 hours ago, Douglas Rink said: Too cool, looks like we’re both getting Apex’s in October then and as an “Honorary Texan” from my time stationed there will share a Big Texas smile with ya. Cheers! I fairness, we moved down from Chicago/NW Indiana 😉 We're picking up in Dec, coincides with an annual trip to visit family in Nashville, so works logistically 🙂
Douglas Rink Posted July 23 Posted July 23 I shall throw no stones at you for that as “in it’s a small world” between us, I was born in Chicago. As you can appreciate, my dad moved us south while I was a kiddo while working for Eastern Airlines at O’hare and fueling jets in the winter was far more tolerable in Charlotte NC than the Windy City! Besides “Texas” is an attitude that can easily be adopted as per all my friends there.
Galileo Posted July 23 Posted July 23 On 7/20/2026 at 4:12 PM, Mike and Carol said: Best bet for a stripped down model is to do what John did and get a “vintage” trailer and take out all the worn out, outdated things and start over. -Supposedly- with Oliver’s “high resale value”, you’re still going to be paying for “worn out, outdated” things. I guess if you can find a motivated seller. (Dad passed away and the kids don’t want the trailer.) you could make this work. It’s all theoretical anyway, but I would thing that NOT putting things into a shell trailer - saving the dealer cost of those items as well as the labor to install them - Oliver (or any company) could make more selling a stripped down model than they could selling a loaded or even average one. It’s not “custom”, it’s just “don’t install X, Y, and Z.” 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators Mike and Carol Posted July 23 Moderators Posted July 23 1 hour ago, Galileo said: -Supposedly- with Oliver’s “high resale value”, you’re still going to be paying for “worn out, outdated” things. I guess if you can find a motivated seller. if I was to sell today I would ask what I paid for my trailer 10 years ago. That’s half of what a new trailer sells for today. 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
