Townesw Posted July 18 Posted July 18 (edited) Please don’t respond with long winded dissertations, conjectures, theories, thoughts, wishes, guesses, etc., etc., etc. As Detective Joe Friday said "All we want are the facts, ma’am” Simply stated : What axles, springs, shocks, EZ Flex Equalizers, shackles and bolts are being installed on Current Production Legacy Elite II trailers being built right now? Also the same for the Apex model? Include part numbers and pictures if you have them. Bill Edited July 18 by Townesw Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
jd1923 Posted July 18 Posted July 18 This information is all here in various threads. I'll summarize while trying to be concise enough! 🤠 All new 2026-27 Oliver models will have D52 Nev-R Lube axles rated a 2x 5200 LBS. But unfortunately, on the EII, OTT will install same underrated springs they installed on all our hulls, the 1750 LB Dexter part # PR4B. These have a long history of failure where the main leaf breaks where the second shorter leaf makes contact. The OTT YouTube video on the Apex stated OTT is using the lighter rated 4-leaf version of Alcan Springs. In the Alcan design, the second leaf is the same length as the main leaf, so it cannot fail in the same way. There are also no gaps between leaves which is often observed on the Dexter PR4B. There must be DOT cost/legal reasons why OTT keeps their products rated at 7000 GVWR. If OTT installed the 5-leaf Alcan it could be rated at 10K. About 200 Oliver owners have installed the Alcan Spring upgrade, most with 5-leaf and a few with the 4-leaf version (without the bottom leaf). Not certain and it really doesn't matter as much, but it makes sense OTT will install the same Dexter EZ-Flex kits on all models which include Dexter shackles and wet bolts. The video also stated the Apex will have Bulldog shocks. OTT will likely keep installing Monroe 555001 shocks on the EII. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
