how do I access the fittings on tbe water heater. I can see a leak either the blue or red hose  going into the insulated water heater.  is there a utube  video on how to get to those fittings. I have trouble turning the valve off for water going into water heater and now there is water spraying out of the blue hose connection..  how do I get to it to repair. my hands won't fit anywhere in there.  do i take the styrofoam insulation off to get more room so I can repair the fitting.  no idea.    or should I take it to bish rv repair in bozeman,mt.. and let them repair it
Edited by Skipster
to add more text
skip and cyd nielsen  hull #822 Elite     tow vehicle 2017 jeep trailhawk v6
so after consulting my chat ai.  i decided fixing it myself would be a big problem for me so i am taking it to bish rv repair in bozeman  montana  .  also having them make it easier for me to access the inline valve for bypassing the tank. I cant get my fingers on it to turn it on and off.   very tight.   also anther problem is the black tank shut off valve does not close all the way and the dump hose is always full    so hope they can repair these issues. so thanks and I appreciate the help and advice
@skipster .. i have a Elite 1. Also. I cut a 6 inch opening, installed access hatch.  Can get the bypass valve much easier.  When i got our Oliver back in 2022 . I told them to move the hole they have back then closer to the valve..  dont know if was ever done.  I know the pics i see of the LEII  there is more room there, reaching from the top hatch panels under the bed..  i hope you get it fixed..
2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
