Today, my unit suddenly indicated through the Xantrex solar unit that the batteries were dead!  New batteries as of last year!  Circuit breakers checked out fine.  Why is the system apparently draining the batteries?
  • Sad 1
Charlie
Hull 734 - 2021 Oliver Elite II
pulled by F-150
Out of Florida
More info please. Type of batteries? What voltage do you see when you press the Battery button on the SeeLevel monitor? Are you plugged into shore power or running off batteries? Do your interior lights work? Do you have a multimeter?
Also -
do you have solar panels?  Do you have a solar panel cut-off switch?
do you have an inverter?  Is it on or off?
do you have a fridge that runs off DC power (i.e. a three way fridge)?  If yes then what setting is the fridge on (a/c, d/c, or propane?
