Citrus breeze Posted September 5 Posted September 5 Today, my unit suddenly indicated through the Xantrex solar unit that the batteries were dead! New batteries as of last year! Circuit breakers checked out fine. Why is the system apparently draining the batteries? 1 Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Steph and Dud B Posted September 5 Posted September 5 More info please. Type of batteries? What voltage do you see when you press the Battery button on the SeeLevel monitor? Are you plugged into shore power or running off batteries? Do your interior lights work? Do you have a multimeter? 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderators topgun2 Posted September 6 Moderators Posted September 6 1 hour ago, Steph and Dud B said: More info please. Type of batteries? What voltage do you see when you press the Battery button on the SeeLevel monitor? Are you plugged into shore power or running off batteries? Do your interior lights work? Do you have a multimeter? Also - do you have solar panels? Do you have a solar panel cut-off switch? do you have an inverter? Is it on or off? do you have a fridge that runs off DC power (i.e. a three way fridge)? If yes then what setting is the fridge on (a/c, d/c, or propane? Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Citrus breeze Posted September 8 Author Posted September 8 I have AGM batteries that test with my multi tester as having full power. However, the Xantrex indicates “dead batteries”, even though the voltage reading on it says 11.7V. It seems to indicate that the Xantrex is not reading the batteries correctly. Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Tom and Doreen Posted September 8 Posted September 8 What is the voltage measured directly on the battery terminals with a DVM? 1 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
Citrus breeze Posted September 8 Author Posted September 8 The voltage directly from the batteries with my multi tester is reading 12.7 V. My Inverter is on. My 3 way refrigerator is not turned on and is therefore not drawing any power. My maxi fan is running on a slow setting. The solar Xantrex controller is showing that I have the 11.7V right now, and is indicating that solar is sending current into the unit. They are new batteries. You see, I’m preparing for our next camping trip this coming Thursday. Does any of this make sense? Charlie Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Citrus breeze Posted September 8 Author Posted September 8 The readings are as follows: IMG_1306.mov Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Tom and Doreen Posted September 8 Posted September 8 I'm not sure how the 2021 trailers are configured for power, mine is a 2023, but if you have an Optifuse circuit breaker on the input side feeding the Xantrex the Optifuse may be dropping some of the voltage. Mine was problematic, the symptom was a low indicated voltage at the Xantrex and when I would run high current devices such as the microwave the Xantrex would shut down. The solution for me was to replace the Optifuse with a marine switch. I would give Oliver a call and they can help to zero in on the issue. 1 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
John Dorrer Posted September 8 Posted September 8 First thing I see is your batteries are below 12.2. All it takes is one time to damage AGM's. They are unforgiving. Street side, at the front next to the actual inverter should be the inverter breaker. If it is tripped you can't charge the batteries. It is also possible that it is bad, and/or the cables are loose. Must be off shore power, solar off, inverter breaker tripped and then batteries off before touching the breaker. I have a 2022 and have had to replace the breaker twice. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Snackchaser Posted September 8 Posted September 8 3 hours ago, Citrus breeze said: The voltage directly from the batteries with my multi tester is reading 12.7 V. Charlie, Based on your measured values, I’d first look at the battery cable to battery post connection(s): 1. If the 12.7 volt measurement was taken directly from the battery posts, then the battery is not dead. 2. The solar directly feeds the battery via the Zamp controller. It does not pass through the inverter or the main battery breaker. So the 11.7 voltage read from the Zamp controller is more likely a voltage drop through the battery post connection(s), not the main breaker. 3. The inverter also shows 11.7 volts, with no load, so it could also be reading a voltage drop through the battery post connection(s). That’s a reasonable analysis, and battery post corrosion is a common problem with AGM batteries. Sometimes the lead battery posts become oxidized. Although they appear fine, oxidization is a poor conductor. Having said all that, you possibly have a different setup or a poor main ground connection. Some simple voltage tests at various connection points would quickly isolate the problem if cleaning the battery posts does not fix the issue. Hope that helps. Cheers, Geoff 3
Citrus breeze Posted September 8 Author Posted September 8 Thanks John, Here’s what my fuse looks like. Are they easy to remove and install? Charlie Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Citrus breeze Posted September 8 Author Posted September 8 Thanks Snack chaser! I intend to clean the battery posts. I’ll check those out. Charlie Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
2008RN Posted September 9 Posted September 9 9 hours ago, John Dorrer said: I have a 2022 and have had to replace the breaker twice. Wow, twice in 2 years that is not very comforting. I wonder how bad is their failure rate? Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
2008RN Posted September 9 Posted September 9 11 hours ago, Tom and Doreen said: I wish my main electrical setup looked this clean. My 2020, is all over the place. Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
jd1923 Posted September 9 Posted September 9 (edited) Yeah but... Given the pics above, we see 11.2V, then 11.1V, then 11.2V which average with great precision in the range of a dead lead acid battery. The OP posted both 11.7V and 12.7V numbers without supporting pics, no mention of the voltage numbers displayed in the pictures. Lead Acid batteries will go to zero, more load-more quickly. In my understanding, given 3 independent readings from 3 independent hardware vendors, Zamp, Xantrex, and SeeLevel; they're all displaying the exact same voltage reading? (within 0.1V deviation on one device). Not likely at all. The batteries are reading near dead but not too low to recharge. Check the multimeter again as wired and check it again with battery cables all detached. It cannot correctly read 12.7V when 3 simple BMS systems are agreeing to 11.2V. Likelihood is the11.2V is correct. Connect to shore power and charge your batteries for 24-48 hours asap. And perhaps it's a blessing, time to scrap the AGMs! In another OTT Forum thread there is a link to well-featured 300 Ah LiFePO4 sale priced at $600. It's a good time to buy lithium. Just one of these batteries will provide 50% more Ah capacity than 4 brand new AGMs. They will last 3x as long and at deliver full capacity in their lifetime. Most who install the LiFePO4 upgrade today go with 600 Ah which will deliver 3x the power! Edited September 9 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted September 9 Posted September 9 (edited) 3 hours ago, 2008RN said: Wow, twice in 2 years that is not very comforting. I wonder how bad is their failure rate? When concerned, replace your DC circuit breakers with ANL or MRBF fuses. You simply know when a fuse burns and there is always a reason behind it. Fuses protect overloads in both directions on the circuit. Simple DC breakers are directional, will protect power to ground faults on one side of the breaker. An issue on the other side of a DC breaker is not covered. I've kept two DC breakers that OTT installed (30A rooftop solar and 40A for jacks, etc.) When I rework something or add a new accessory, I prefer to add a fuse holder over a breaker (only in 12VDC systems). Just keep those breakers/fuses and switches out from under your spouse's bed! 🤣 Edited September 9 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John Dorrer Posted September 9 Posted September 9 (edited) On 9/8/2026 at 10:09 PM, 2008RN said: Wow, twice in 2 years that is not very comforting. I wonder how bad is their failure rate? Not sure where the "twice in 2 years" came from. Twice in 5 years. The last one may have been on me for not checking the cable connectors. The cables were loose, there had been arching and the cable ends were pitted. I felt better replacing it just in case, and now turn everything off and check tightness after our last trip of the year. The first day of ownership it tripped. It tripped again and Oliver sent me a replacement in 2022. Oliver stopped using the breaker in 2023 or 2024 and now use a large fuse. Edited September 10 by John Dorrer Updated Comment 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
