Dean and Mary Posted Saturday at 04:58 PM Posted Saturday at 04:58 PM Imelda, Thanks for the update, and I’m glad you’re able to get home with things as they are. Just a quick reminder—the jacks don’t receive their power from the converter, but more of a direct connection from the batteries through the 60 amp Optifuse shown in my above image. 2 TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC – DC charger, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
jd1923 Posted Saturday at 05:16 PM Posted Saturday at 05:16 PM 1 hour ago, Imelda said: the 60A fuse is good just checking the low resistance (not the voltage but I will) across it. Does this mean the "fuse is good?" it's certainly not a conclusive test and it doesn't mean there's a 12V source connected to the breaker. +12V on the source side of the breaker shows you have connection to the batteries. +12V on the load side shows the breaker is closed providing a power connection to the bus. 1 hour ago, Imelda said: I am starting to suspect the converter. A dead (or disconnected) converter will only keep you from recharging batteries when connected to shore power. A running converter is not required to operate lights, the jacks or anything else 12VDC. Converter status is independent of these 12V loads getting power from the batteries. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted Saturday at 06:27 PM Posted Saturday at 06:27 PM (edited) 4 hours ago, Dean and Mary said: jd, thanks for sharing the photo of your original 12‑volt distribution. It’s definitely cleaner than what my original setup looks like. I’ve attached a photo of mine—minus the 8‑gauge input wire. I’m in the middle of replacing everything and wanted a picture before I completely disassemble it. On my install, there are two wires on the input side of the Optifuse (not counting the main 8‑gauge battery feed that’s been removed). I haven’t traced them yet, but I suspect one may be for the breakaway switch. I don’t want to hijack the thread until the main issue is resolved, but identifying these wires would save me some time. Dean, WOW! I've seen some strange wiring but what happened here? Did they run out of buses on install day? The installer just bolts everything to the breaker, OMG! 🤣 BTW, this is the famous Optifuse! Many of these have failed, so that OTT has stopped using them! Search the Forum for keyword Optifuse. I'd be surprised if this isn't the answer to the issue of this thread, since everything not working, lights, jacks etc. is connected to this breaker. Do yourself a favor with your upgrade and replace the Optifuse breaker with an 60A ANL fuse and holder. Oh, and add a +bus, LOL! Back in 2016, OTT used Bussman breakers (at least on our hull). They installed a 40A for all 12VDC lighting, jacks, etc. (pictured above) and a 30A Bussman for the rooftop solar. Keeping things standard, I purchased a 35A Bussman breaker to protect the Victron MPPT 100|30 SC that I added for our 400W Renogy suitcase solar. Three Bussman breakers, 2 of them 11 years old, the new one 2 years old, no issues. ANL fuses are more reliable as you certainly know when they are blown (always have a spare). Fuses will blow when there's too much current on either side of the fuse. Breakers are directional, so they only protect on the load side of the breaker. I have no idea what your two black wires are on the source side of your breaker. Trace them back if you can. If not, I'd wire them to a new bus with everything else. I have no wires before a breaker anywhere, meaning power to the breakaway switch on our hull does pass though the 40A breaker (OTT had not wired this to code). I know the breakaway switch works because I pull it to test for amperage to the brakes. When I moved these breakers to the dinette area, I found the wiring from the jack fuses to all 3 jacks ran towards the dinette area first (was surprised since one jack is right there and the curbside jack is another direction). I removed all that excess wire and removed 3 butt connectors on each of the 3 wires along the way. I crimped one fresh butt connector on each of 3 much shorter wires to clean things up. 😎 Edited Saturday at 06:47 PM by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted Saturday at 11:39 PM Posted Saturday at 11:39 PM 20 hours ago, Hokieman said: Did you see the manual? It’s got over a dozen diagrams in it, I just did a snip of one of them. Most of the circuits are shown. Thank you. I had not checked out the 2019 Oliver Manual before. I just downloaded a copy. I see many differences comparing our older hull but still can be helpful. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Dean and Mary Posted yesterday at 01:15 AM Posted yesterday at 01:15 AM 6 hours ago, jd1923 said: Dean, WOW! I've seen some strange wiring but what happened here? Did they run out of buses on install day? The installer just bolts everything to the breaker, OMG! 🤣 BTW, this is the famous Optifuse! Many of these have failed, so that OTT has stopped using them! Search the Forum for keyword Optifuse. I'd be surprised if this isn't the answer to the issue of this thread, since everything not working, lights, jacks etc. is connected to this breaker. Do yourself a favor with your upgrade and replace the Optifuse breaker with an 60A ANL fuse and holder. Oh, and add a +bus, LOL! Back in 2016, OTT used Bussman breakers (at least on our hull). They installed a 40A for all 12VDC lighting, jacks, etc. (pictured above) and a 30A Bussman for the rooftop solar. Keeping things standard, I purchased a 35A Bussman breaker to protect the Victron MPPT 100|30 SC that I added for our 400W Renogy suitcase solar. Three Bussman breakers, 2 of them 11 years old, the new one 2 years old, no issues. ANL fuses are more reliable as you certainly know when they are blown (always have a spare). Fuses will blow when there's too much current on either side of the fuse. Breakers are directional, so they only protect on the load side of the breaker. I have no idea what your two black wires are on the source side of your breaker. Trace them back if you can. If not, I'd wire them to a new bus with everything else. I have no wires before a breaker anywhere, meaning power to the breakaway switch on our hull does pass though the 40A breaker (OTT had not wired this to code). I know the breakaway switch works because I pull it to test for amperage to the brakes. When I moved these breakers to the dinette area, I found the wiring from the jack fuses to all 3 jacks ran towards the dinette area first (was surprised since one jack is right there and the curbside jack is another direction). I removed all that excess wire and removed 3 butt connectors on each of the 3 wires along the way. I crimped one fresh butt connector on each of 3 much shorter wires to clean things up. 😎 Thanks for the detailed response. I agree—the wiring is a mess, and that’s exactly why I’m redoing all of it. I did not know about the failure rate of the Optifuse. I’m also curious about the maximum of three wires on a lug, and why there are two connections ahead of the Optifuse. For my upgrade, I’ll be using the Victron Energy Lynx Distributor with ANL fuses. 1 TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC – DC charger, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
Snackchaser Posted yesterday at 01:45 AM Posted yesterday at 01:45 AM 21 minutes ago, Dean and Mary said: why there are two connections ahead of the Optifuse. Those are probably the emergency breakaway switch for the breaks and the CO monitor. They take a direct feed from the battery. 1 1
Dean and Mary Posted yesterday at 03:13 AM Posted yesterday at 03:13 AM 1 hour ago, Snackchaser said: Those are probably the emergency breakaway switch for the breaks and the CO monitor. They take a direct feed from the battery. Thanks Snackchaser, that makes sense. TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC – DC charger, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
