shhQuiet Posted 8 hours ago Posted 8 hours ago I recently added a small single-board computer (Raspberry Pi) to my Oliver and a few other doodads that integrated everything into a single application called "Home Assistant". This is meant for home automation and control. Open-source, completely free. Rather than go into the details, I'll just show a few screenshots here. If anyone is interested in how/why, let me know and I could also do a "mods" video and show all the details. I sort of went down the rabbit hole on Home Assistant 😂. Here's the main screen- it shows a group of alarms across the top, from Victron, batteries, Xantrex, etc. I also have some little bluetooth temperature/humdity probes. I bought a 3-pack from Amazon and they were pretty cheap. One is mounted in the cabin, one under the propane cover and one in the fridge. You can set warning for high/low temp, so that's why the fridge is showing an alert (since it's turned off). I added a USB GPS receiver to the Raspberry Pi and it will display a little map of where the Oliver is. The "Temperatures" screen has all the temp/humidity sensors on one page The "Energy Flow" page is pretty interesting: I also added a 3D-accelerometer, but it is still an experiment. I plan on fixing the sensor to the hull and then implementing some kind of helper for leveling. I also wanted to track the amount of bumps and swaying that happen while towing. Not showing much right now since it is parked. Still playing with this one: More stuff on the main page: All this stuff is wired in and installed beneath the aft dinette seat. All the stats are logged indefinitely for now on an SSD drive, so you can pick a date/time range and see what was going on. I'm a bit of a geek if you can't tell 😁 One the very best benefits of all this is that I can see it from the HA app on my phone. I can also control things with the phone- I can remotely turn on/off the inverter, which lets me set it up so that I can go out and then use my phone to turn on the inverter (and AC if it is turned on). I think the only thing that is not being monitored is the fault code from the Progressive Industries EMS box. Let me know if you have any questions! -Steve 1 2 2023 Oliver Legacy Elite II, Hull #1405, "Rocinante" TV: 2022 F-150 5.0 V8 4x4 YouTube: StevesRoadTripChronicles
dewdev Posted 5 hours ago Posted 5 hours ago Very neat monitoring system. How were you able to interface the individual equipment into your Raspberry Pi? Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
shhQuiet Posted 3 hours ago Author Posted 3 hours ago 2 hours ago, dewdev said: Very neat monitoring system. How were you able to interface the individual equipment into your Raspberry Pi? Thanks! Most everything is bluetooth (Victron, solar panels, solar charger, batteries, temperature sensors). I have a travel router (which I didn't mention), that is connected via ethernet. The GPS receiver connects via USB. The Xantrex was the tough one (and the best one to have). It has bluetooth, but in my experiments, it would disconnect immediately whenever I tried to send it a command. I think their phone app must have some "secret handshake" before it will work. So, I ordered a 40-pin connector that connects to the Xantrex and gives you a CAN bus interface over a shielded twisted pair cable. I then used a cheap ($20) USB CAN bus adapter connected to the Pi via USB. The Xantrex implements a subset of CANBUS called RV-C (RV industry related), so all the reading of values and setting variables is using the public RV-C protocol. 2023 Oliver Legacy Elite II, Hull #1405, "Rocinante" TV: 2022 F-150 5.0 V8 4x4 YouTube: StevesRoadTripChronicles
Snackchaser Posted 2 hours ago Posted 2 hours ago 5 hours ago, shhQuiet said: Let me know if you have any questions! Steve, great work! You're very tenacious for getting this done. Hats off to you, and thanks for sharing! I had thought of doing something like this with a Pi, but with a built-in display for both the trailer and truck to include DC to DC charger performance. Anderson now makes high amp connectors with up to 8 auxiliary wires that might be adaptable, even for an AC switch!. But what I really wanted was accurate tank and propane levels. The Mopeka sensors work with Home Assistant, and I heard they are better than they used to be. But I was waiting for the radar based ones to develop and come down in price. The other problem is that the Oliver’s fresh and grey water tanks are so long and shallow that being even slightly off-level throws off the reading. Wait… your accelerometer could fix that! The Pi could calculate the tilt and correct the tank reading. Reading the Lithionics batteries over Bluetooth was very clever. Were you able to do everything within Home Assistant, or did you have to write some code? Some of the pages look custom. I figured you must be reading the Xantrex over both the RV CAN bus and Bluetooth, again very clever. This was always a hold-up for me, and one reason I never went with a Cerbo as an option... as well as its very limited inputs. I'd love to see your list of integrations, add-ons, and any custom cards you're using. Cheers! Geoff 1
shhQuiet Posted 1 hour ago Author Posted 1 hour ago 54 minutes ago, Snackchaser said: Steve, great work! You're very tenacious for getting this done. Hats off to you, and thanks for sharing! Well, thanks so much! I actually started thinking about a display and I wanted e-ink, but got hung up on the mounting and the powering (plus the $) so I just went with the Home Assistant apps for mac/iphone/ipad. You make a good point about using the accelerometer for compensating for the tanks. I thought about adding my own sensors and just leaving the SeeLevel ones in place. ... I'd also really like the propane level- Might could put a load cell under the tank and weigh it... There is custom code, not only for the UI but also integration for the accelerometer which is a custom little board I made. I used Codex to write most of the code... I setup the credentials and the Oliver was out in the driveway and Codex was logging into it and configuring. The most painful part of the whole deal was paying $49 and waiting 3 weeks for the Xantrex 40-pin connector! 2023 Oliver Legacy Elite II, Hull #1405, "Rocinante" TV: 2022 F-150 5.0 V8 4x4 YouTube: StevesRoadTripChronicles
Snackchaser Posted 1 hour ago Posted 1 hour ago 3 minutes ago, shhQuiet said: Well, thanks so much! I actually started thinking about a display and I wanted e-ink, but got hung up on the mounting and the powering (plus the $) so I just went with the Home Assistant apps for mac/iphone/ipad. You make a good point about using the accelerometer for compensating for the tanks. I thought about adding my own sensors and just leaving the SeeLevel ones in place. ... I'd also really like the propane level- Might could put a load cell under the tank and weigh it... There is custom code, not only for the UI but also integration for the accelerometer which is a custom little board I made. I used Codex to write most of the code... I setup the credentials and the Oliver was out in the driveway and Codex was logging into it and configuring. The most painful part of the whole deal was paying $49 and waiting 3 weeks for the Xantrex 40-pin connector! 3 minutes ago, shhQuiet said: Might could put a load cell under the tank and weigh it... Huh, I looked into load cells a few years ago, just couldn't find anything to adapt. Please let us know if you find something, that would be a game changer. I currently use a handheld luggage scale for the most accurate propane measurements, short of buying a mechanical level tank. I still have hateful memories of the Mopeka sensors! 1
shhQuiet Posted 1 hour ago Author Posted 1 hour ago Another really game-changing aspect is the Oliver's local network. I had never heard of a "travel router" before, but they are very small wifi routers that connect and are powered by USB. The way they work is you have all your devices connected to the travel router's wifi always. When you travel, you can use the travel router to connect to different things, like a campground WiFi, or Starlink or whatever. That way, you don't have to reconnect all your devices. Plus it provides a layer of security over just using a public wifi. Along with that, I use a service called Tailscale, which is really great. It allows your devices to join a private VPN and they can communicate over the public internet. That's how I can connect my phone from anywhere to the Oliver. Tailscale is free with a limit of 100 devices. I think I have 7- like mac, iphone, ipad, oliver, a few others. I know it's a lot of information if you're not interested, but I am tickled with how it works and how much it costs, other than the doodads I bought to get it all hooked up. No monthly service fees! 1 2023 Oliver Legacy Elite II, Hull #1405, "Rocinante" TV: 2022 F-150 5.0 V8 4x4 YouTube: StevesRoadTripChronicles
Snackchaser Posted 4 minutes ago Posted 4 minutes ago 1 hour ago, shhQuiet said: know it's a lot of information if you're not interested, but I am tickled with how it works and how much it costs, other than the doodads I bought to get it all hooked up. No monthly service fees! That's great information, I'm going to look into it. I have a custom WiFI based app for my automatic trailer leveling system. Problem is that Starlink has priority - so app takes back seat. Kind of spoils its convenience. Thanks for sharing that! Geoff
