Anyone have a suggestion for a good product to remove tar and bugs without damaging the finish. Also has anyone ever run their Oliver through a "touchless" truck wash?
Thanks...Leigh
Olive Oyl
2015 GMC Yukon
2016 Legacy Elite II
Hull # 132
We use Thetford Black Streak & Bug remover for RV gelcoat, fiberglass, and painted aluminum. OK to use around windows or decals, too. Buy it at the local Walmart. I'm in a habit of cleaning bugs, stains, and tar off of the front of the camper & TV with a soft cloth and bug/tar remover at the end of each travel day.
http://www.thetford.com/product/ultrafoam-rv-black-streak-bug-remover/
Use bug and tar remover by Turtle Wax for our pick up trucks.
https://www.turtlewax.com/shop/products/turtle-wax-renew-rx-bug-tar-remover-16-fl-oz
Use Plexus to clean plastic windscreens on motorcycles, helmets, and airplanes:
http://www.plexusplasticcleaner.com/about.html
Always wash the Ollie at home with fiberglass boat wash.
Leigh,
After you get the bugs/tar off, a good coat of wax will help you the next time you have to remove "stuff".
I agree with rideand fly - plexus is great for anything plastic.
I use WD 40 to lift the bug debris initially, but just soaking the area in question with a wet towel laid over the area for several hours will also do wonders.  I do this on my motorcycle fairing and screen.  On the airplane I just soak the windshield with anything liquid then use Plexus.  As mentioned use a thick coat of Plexus, regular car wax, or PlastiX product to serve as a polish.  I never try just washing them away, its futile.
