Moderators topgun2 Posted September 27, 2016 Moderators Share Posted September 27, 2016 Unfortunately I store Twist at a storage facility that is basically a fenced in field. Security is OK but there is no cover. Therefore, I'm looking to purchase a cover and my problem is that Twist is presently at the Mother ship and I need a measurement. Can anyone give me the distance from the spare tire cover to the base of the propane tank cover? Thanks in advance for the help! Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
rideandfly Posted September 27, 2016 Share Posted September 27, 2016 Bill, Came up with 20' 4" from front of LP Gas cover to top/rear of tire cover. The license plate light adds 1 1/2" to that overall dimension. Hope that helps! 2 Bill & Debbie / 2015 LE2 #75 / 2024 F-150/5.0L / North Carolina Link to comment Share on other sites More sharing options...
wave1127 Posted September 27, 2016 Share Posted September 27, 2016 hi bill! we actually ordered a custom cover for our elite II from calmarkcovers.com here is a screen shot of our measurements. it's a nice cover, seems like a durable material, easy to put on and very secure. we've had it for 4 months now and it's holding up well in the hot florida sun. the fit is not perfect but it serves its purpose. 2 Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted September 28, 2016 Author Moderators Share Posted September 28, 2016 Bill and Wave1127, Thanks so much for the help - exactly what I needed. There is a difference between the two overall measurements - 20' 4" versus 19'. I suspect that is mainly due to not including the spare tire cover on one versus the other. But, in any case I do not think it has material impact on an RV cover of this size. Wave1127 - If you were to order a new one from Calmark what would you do differently to make it "perfect"? Do you have solar? If yes, did you use something to pad the edges of the panels prior to putting the cover on? I was thinking of using "pool noodles" or simple pipe insulation. Also, do you have a wineguard TV antenna? Did you do anything to it prior to putting the cover on? Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
rideandfly Posted September 28, 2016 Share Posted September 28, 2016 Bill, The top of the tire cover is 11" including license plate light and I rounded up to the next higher inch using sight when measuring from the side for the overall Ollie length measurement including the tire cover. Hope this helps, Bill & Debbie / 2015 LE2 #75 / 2024 F-150/5.0L / North Carolina Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted September 28, 2016 Author Moderators Share Posted September 28, 2016 For those with inquiring minds (and for what its worth) the three measurements of the Legacy Elite II from the front of the propane tank cover to the rear of the spare tire cover that I have so far are: Rideandfly - (244") Wave1127 - (243") plus something for the spare tire cover? Tommy Staggs - (247 to 249") Since one must "eyeball" the measurement (unless you want to go to more trouble than it is really worth), all of these measurements are well within the limits necessary for the purpose of either ordering or buying a ready made cover for the Oliver. As it is said on the CalMark measuring sheet, "Ever try to measure an egg?". Thanks to all for the help! Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
rideandfly Posted September 28, 2016 Share Posted September 28, 2016 Bill, PM Sent Bill & Debbie / 2015 LE2 #75 / 2024 F-150/5.0L / North Carolina Link to comment Share on other sites More sharing options...
