John E Davies Posted September 26, 2020 Posted September 26, 2020 (edited) This is super easy..... Little House Fridge Button Guard - scroll 3/4 of the way down to view I have only mistakenly switched to DC once, and I caught it in time before the batteries went flat. The DC "heater" inside the fridge draws 15 amps continuously. It isn't something you want to leave operating more than an hour or two. Here is the DC/AC select button: The plate is clear plexiglass, maybe 1/4" thick or so. Follow the included instructions and install it. Center the guard left and right and also vertically, make sure it is level, and when you are satisfied push GENTLY. Make sure it looks good and none of the buttons bind in the guard holes. Mine were fine, if yours stick, remove and reposition the guard slightly. Once pressed firmly and held for half a minute, it won't move. The lights are easily seen, but eventually the dust will collect back there, so maybe a blast of compressed air might be needed in the future. I can't get my index finger inside the holes, but my pinky works fine. I can't see any of these buttons being pressed by mistake. The plastic will scratch easily and any harsh solvent may cloud it, so be gentle when cleaning the area. Do NOT spritz it with 409, the soap will run behind the plastic and you won't be able to get it all out. John Davies Spokane WA Edited September 26, 2020 by John E Davies 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators topgun2 Posted September 26, 2020 Moderators Posted September 26, 2020 (edited) Tractors 1 (Charlie Y) - RV WIDGET WORKS - is or was a member of our Forum - I've not noticed him here recently though. He is the originator of the shield JD mentions above. If anyone is interested, you might want to try sending him a PM or contact RV Widget Works and cut out the middle man. Bill Edited September 27, 2020 by topgun2 Typo and more info 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted September 27, 2020 Moderators Posted September 27, 2020 Charlie sent me several guards before the last rally when I gave the class Camping for Dummies. I gave away a couple and still have one. I’ll bring it to the next rally for someone. We’ve had ours on for 4 years, after someone’s backside turned our fridge off! Send him a PM and he should answer. I think his forum name is tractor1. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
