Rivernerd Posted October 27, 2023 Share Posted October 27, 2023 On 10/25/2023 at 6:26 PM, SeaDawg said: My husband actually designed and built the manifold. Not a lot of plumbers in rural Central Idaho use Uponor/Wirsbo Pex-A either. I also designed and built the manifolds, and did all of the plumbing in our home. After 4 years, no leaks in the Pex. 3 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package Link to comment Share on other sites More sharing options...
Hokieman Posted November 19, 2023 Share Posted November 19, 2023 On 10/25/2023 at 7:10 AM, topgun2 said: I view Sharkbite fittings as an emergency plumbing part. I keep a couple of 3 foot lengths of Pex and a small assortment of Sharkbite fittings in my Ollie - just in case. I also carry some spare Pex A tubing & a few Sharkbite fittings. Last trip we lost water pressure after a long day of highway driving. A look outside revealed water draining out one of the scupper holes. A look under the curb side bunk showed a broken plastic elbow on the bottom connection of the Suburban water heater. I did not have the correct Sharkbite fitting on hand (I needed a 1/2” el), but found a Home Depot 10 miles away open until 9 pm. The repair was made quickly, and camping continued. When I got back home I re-plumbed both the bottom and top water heater fittings with simple 1/2” brass els, as the plastic elbows are not the best, and they restrict the water flow when compared to similar 1/2” brass. I used Sharkbite copper crimp rings and a compression tool I already own. I’m familiar with the benefits of Pex A tubing & fittings used in residential plumbing. Since OTT used Pex B and copper crimp rings throughout my trailer, I did the same. It’s easy to do, and it’s the most common DIY method. These Pex B parts are readily available at most good hardware stores. Some time ago, I removed the restrictive plastic T-fitting used for the flush toilet water supply under the bath sink. I removed that supply line as well as the valve behind the toilet. Since I have a Natures Head toilet, the water supply line and valve is not needed, and is another item to winterize. I also removed the black tank flush linens and vacuum break fitting. The result of replacing the restrictive plastic water supply fittings is a noticeable improvement in water flow, especially in the shower. 1 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250 Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted November 19, 2023 Moderators Share Posted November 19, 2023 11 hours ago, Hokieman said: A look outside revealed water draining out one of the scupper holes. A look under the curb side bunk showed a broken plastic elbow on the bottom connection of the Suburban water heater. I had the same issue with the T fitting coming out of the hot water tank. The plastic cracked just enough to cause a steady drip. We discovered it on the way home after a long trip so I fixed it after we got home. Replaced the plastic with brass. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
