AndrewK Posted December 14, 2021 Posted December 14, 2021 For those who have the RVLock keypad on your door and have been frustrated with the poor-quality keypad sticker, you will be interested in this upgrade. RVLock has come out with an upgraded one-piece silicone keypad membrane with numbers. The silicone membrane replaces the poor-quality keypad sticker and the silicone pad. The upgrade does require removing the lock and unscrewing the internal keypad to install the new membrane. (Instructions pictured) If you are interested, you will have to email or call RV Lock directly as the item is not "available to the public" and not listed on their website. I was given the okay by RVLock to pass the information about the upgrade on to the Oliver Owner's, via the Forum. The "UPGRADED SILICONE RVLock V4 RH Keypad Membrane" was $19.99 + $4.99 shipping. I hope this helps solve a problem. Andrew 2 3 Andrew 2019 Legacy Elite II 2018 BMW x5 35d
Moderators topgun2 Posted December 15, 2021 Moderators Posted December 15, 2021 Patriot mentioned this keypad upgrade in THIS THREAD. Bill 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted December 17, 2021 Posted December 17, 2021 On 12/14/2021 at 7:17 PM, topgun2 said: Patriot mentioned this keypad upgrade in THIS THREAD. Bill A worthy replacement! 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
