Showermi$er
Steph and Dud B
This is a great idea for saving water while boondocking. Would love to see Oliver add this to their trailers:
"Several RVs feature a SHOWERMI$ER system. You can flip a lever and the water that would otherwise come into the shower gets diverted directly back into the fresh water tank while waiting for the hot water."
https://aquaviewinc.com/rv/
ALAZCACOCTDEFLGAIDILINIAKYLAMEMDMAMIMNMSMOMTNENVNHNMNYNCNDOHOKORPASCSDTNTXUTVTVAWAWVWIWYmed.jpg.b96241bad6752dec89d25af6ffbc8d99.jpg
View Inventory
I think that from Oliver’s standpoint, if they we’re to go though the trouble of plumbing a recirculating line back to the fresh tank, then they might as well plumb it back to the water heater and just offer the Truma Comfort Plus as standard.
But from a modification standpoint, I think it’s an interesting idea to plumb back to the fresh tank. Although I think you’d end up with a better looking solution just using a standard shower diverter valve - that little section of exposed blue pipe is a bit weird.  I think you could do the plumbing all within the vanity with only the handle exposed, mounted to the right of the caddy.
Might create a small campground flood if you inadvertently opened that valve while hooked to city water. 😂
Would be interesting to see someone tackle it.  Of course, if you go that far…
And, you've wasted a lot of propane. I've read about that happening on Forest River forums.
I've been watching this since it was introduced,  five or six years ago. Like Overland,  I thought the exposed length of blue thetmal color changing tubing was ugly, and looked like a shoddy install.
You'll find a wealth of comments on forest river forums. Some are happy, many say it doesn't work well with an instantaneous water heater.  That, i don't know.
As much as I  think it's a plausible solution, correctly installed, I'll stick with collecting cold water in a kettle, and use it for dishes . (Heat it on the stove.)
