The EZTire TPMS (like this) also does not have to be rotating to read temp and pressure..
On 12/7/2022 at 7:51 AM, dewdev said:
I use the TireTracker TPMS system. Using the instruction manual, I found it very easy to program.
My TV already had its own TPMS system so I added only the Ollie to the TireTracker system. For those without a TPMS on their TV, the TireTracker system has enough capability to add both the TV and the Ollie.
I bought the TST 507 tpms for both the LE2 and the TV.  My reasoning for the tv sensors was that as I understand it, the vehicle sensors are for pressure only.  I wanted to see the temperatures too.  I bought a ViAir to air up the tires as needed.
Bill, my TST 507 gives readings without needing rotation also.  It takes a few minutes to get readings from all the tires so I typically turn it on ten minutes or so before we leave.  I haven't needed to install the repeater for the trailer.
