David Peters Posted May 6, 2022 Posted May 6, 2022 I have the Elite II and look to store in a tight storage facility. The entry surface is asphalt and level but concerned about backing it in and was considering a trailer dolly. Any recommendations on an electric dolly. Any thoughts on using a non electric dolly given the surface is flat? thanks
Moderator+ ScubaRx Posted May 6, 2022 Moderator+ Posted May 6, 2022 A less expensive option is a front hitch on your truck. You can thread a needle in this configuration. 4 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Patriot Posted May 7, 2022 Posted May 7, 2022 1 hour ago, ScubaRx said: A less expensive option is a front hitch on your truck. You can thread a needle in this configuration. Steve, When you said threading a needle this comes to my mind….or me actually trying to tie a fishing knot. 1 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Patriot Posted May 7, 2022 Posted May 7, 2022 David Peters, Here is an option, not cheap and I am not so sure how well it would work on gravel. https://parkit360.ca/collections/trailer-dollies?utm_campaign=**LP+-+NonTM+-+General+-+US&utm_term=trailer mover&utm_source=adwords&utm_medium=ppc&hsa_kw=trailer mover&hsa_acc=4630284090&hsa_mt=p&hsa_grp=125520177799&hsa_tgt=kwd-389207204846&hsa_src=g&hsa_cam=14379722857&hsa_net=adwords&hsa_ad=540856145407&hsa_ver=3&gclid=CjwKCAjwjtOTBhAvEiwASG4bCGqQikNdOUByI8n0loaLWdphea4wj9ANsf40nwbEvNErO0qc8Ej7qRoC2z8QAvD_BwE 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Steve and MA Posted May 7, 2022 Posted May 7, 2022 We have the Parkit360 Force 10K and use it to pull the hitch end of our LE2 into a corner. A front receiver would be no help since we pull the hitch to within about 6 feet from a wall. Speaking of the hitch, the Bulldog doesn't work well with the dolly without the EZ Connect Hitch Adapter. The manufacturer says their dolly doesn't work with the Bulldog hitch, but this guide was published before they made the adapter: Your Guide to Different Hitch Styles: Choosing the Perfect Trailer Dol – Parkit360 The dolly has enough power and grip on pavement to easily move the trailer, but it probably wouldn't work well on gravel. Sometimes the wheels slip on smooth level pavement, usually when pushing the trailer wheels over irregularities like the driveway apron. 3 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
