Dave and Dana Posted November 13, 2022 Posted November 13, 2022 Hi, does anyone have tips/suggestions to easily put the winter cover on an Ollie II? Thanks TV 2020 Audi Q7, no weight distribution hitch. Ollie E2, Hull #1081, born April 2022.
Moderators topgun2 Posted November 13, 2022 Moderators Posted November 13, 2022 Are you talking about the "old" (heavy) cover or the newer (light weight) covers? Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Dave and Dana Posted November 13, 2022 Author Posted November 13, 2022 I took delivery in 2022, so likely the newer one. TV 2020 Audi Q7, no weight distribution hitch. Ollie E2, Hull #1081, born April 2022.
dewdev Posted November 13, 2022 Posted November 13, 2022 Dave: You could use the search bar in the upper right corner. The subject has been discussed a few times in the past, but I am sure others will chime in and repeat their method of installing and taking off. Make sure you cover the sharp edges, like the solar collectors so they do not tear the cover. 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators topgun2 Posted November 13, 2022 Moderators Posted November 13, 2022 OK - assuming the lighter one: 1. as dewdev points out above, cover/pad all sharp edges. The solar panels are the biggest and next would be the bumper. Pool noodles are your friend for both of these. 1a. don't forget to remove the antenna of the rearview camera if you have one. 2. lay out the cover on the ground with the front of the cover at the front of the Ollie and the back at the back. 3. Either get up on a ladder or use "painter's poles" with tennis balls on the ends to protect the cover (thanks to Patriot for this "painter pole idea) to feed the cover onto the roof and over obstacles that are on the roof. Adjust the cover using the poles or while on the ladder both front to back and side to side. 4. Batten down the hatches. 5. Grab a adult beverage an admire your work. Bill 1 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Dave and Dana Posted November 14, 2022 Author Posted November 14, 2022 Thanks! Can’t wait to give it a try! Dave TV 2020 Audi Q7, no weight distribution hitch. Ollie E2, Hull #1081, born April 2022.
