I went to my covered storage facility last week and took my Honda 2200i generator to charge up my AG batteries. I noticed the Surge protector showed an Error code 9.  Everything was working, including my batteries charged back to full.  Any thoughts?
Are you using a generator bonding plug in your generator?
The Honda’s require a neutral/ground bonding plug that is inserted into the generator outlet that is not supplying power to the trailer.  Search YouTube for Mike Sokol.  He has some valuable information.
On 12/22/2022 at 8:22 PM, Coach and JoJo said:
I have an adapter that i got from Honda....I do not know if it is a bonding plug....
I think it is.  You said in your first post that your batteries were fully charged by the generator.  It won’t do that unless you have a bonding plug.    Next time you hook up the generator, if your code is not reading E0, try turning off the main AC breaker to see if it doesn’t reset.  I’m guessing the system is operating normally.
