Galway Girl Posted February 10, 2023 Posted February 10, 2023 Ford finally launched their VIN specific towing calculator. After inputting your VIN it allows you to input values for Passenger wt, box payload, and choose between Goosneck, 5th wheel or conventional bumper trailers. it calculates remaining available tongue weight and total max trailer weight. link below: https://t.m.email-ford.com/r/?id=h74cb0e7e,8d77749d,7c1fa34e&e=Y2lkPVBST0RETTk4MTk5MyZiaWQ9MTk1OTQ2NDU3NCZwMT13d3cuZm9yZC5jb20vc3VwcG9ydD9lbWFpbGlkPUZEXyBUUlVDSyBUT1dJTkcgRVhQRVJJRU5DRSBFTV9GLTM1MCBPV04&s=5Ij45wNQTUXCV4HKKrOWf8DmysLGRqmuRHqVkfPBOSs The towing support you need. Towing just got a whole lot easier with the new Towing Calculator. Follow these steps to help make sure you’re within your vehicle’s towing capacity: Log into www.ford.com/support/ using your existing account information. Once logged in, click on the Towing Calculator tile in your owner’s dashboard. The calculator will automatically pull in your vehicle’s towing capacity based on your VIN number. Add your occupant, cargo, and accessory weight. Determine whether or not you’re within your vehicle’s towing capacity and make adjustments accordingly. It’s that easy! 1 5 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
BBL Posted February 10, 2023 Posted February 10, 2023 32 minutes ago, Galway Girl said: Ford finally launched their VIN specific towing calculator. You beat me to this post by about 23 minutes! Good thing I checked the sidebar to see what the latest trends were. You were much more thorough that I was planning to be, by the way. Thanks for the share. Brian 3
Zodd Posted February 10, 2023 Posted February 10, 2023 This is cool. However, I wish they would do this outside a login so you take any VIN (like when shopping for a truck) and easily get the real numbers. Ram has this and it is really nice (even if they do seem to have a bug in it right now) Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Moderators topgun2 Posted February 10, 2023 Moderators Posted February 10, 2023 I just read my email from Ford on this and it sounds really useful. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
TexasGuy Posted February 17, 2023 Posted February 17, 2023 So interesting that max trailer weight is different than sticker on my truck. Payload is correct but max towing is a bit less. Now I’d never get near the sticker or calculator but thought it is interesting that it is different. I have read on some Superduty forums that some of differences are significant and folks are rightly upset if Ford is changing specs after they sold a truck. I am guessing maybe calculator needs some work otherwise expect lawsuits if they sold a truck rated for 20k lbs of towing that now says 15k lbs. 2021 Legacy Elite II Hull #807 - 2021 F150 w/ 3.5L EB and max tow package
Mighty Mo Posted February 17, 2023 Posted February 17, 2023 I might be missing something but I don't see the calculator on my Ford page. It must be for trucks newer than mine. I have 2016 F-150 Lariat. Martin & Annie, Austin, TX 2022 LE2, Hull#1240: MightyMo Tow Vehicle: 2016 F-150 Lariat 5.0L V8
