My Truma Aqua Go shows an E 25 W error code (Flue fan current consumption error). What’s the fix before I call Truma.
Thanks
Robert Youens
2023 LEII Hull #1304
TV 2022 RAM 1500 5.7L Hemi e-torque with tow package
Just guessing here but is your  flue blocked or is the fan not operating / jammed? If you have the antifreeze kit is the yellow flue plate removed?
Mud dauber nest attached to fan blades. I had peered into the flu and saw the typical dried mud dauber mud crumbs. I took the plunge and removed the fan. Sure enough there was the nest and mud on the blades where it had been attached. Cleaned the blades, tossed the nest and reassembled the fan to the Aqua Go. The hot water heater is back in business. Thanks so much for the hints.
By the way the screws are T15 Star drive. I was fortunate and had a long enough magnetized screw driver that allowed their removal with less chance of loss.
And one more item. The mud dauber came by while I was working and said, “What the heck!”.
  • Haha 2
Robert Youens
The flue plug is is the flue. Any other suggestions for keeping the little critters out. Are others using screens or ?.
Robert Youens
Don’t know about screens, but I am sure there is a solution. You should be very sure to clean off ALL the mud, the fan blades are balanced and any concentrated mass like that mud will throw that off. It will eventually make noise and maybe damage the bearings. I bet the fan assembly is pricy! A simple dust accumulation may affect airflow a little , but it won’t affect the balance.
spokane WA
spokane WA
Robert Youens
"Any other suggestions for keeping the little critters out. Are others using screens or ?. "
It is recommended to spray peppermint oil in areas where you want to deter mud dauber nest building:
"Repel Them With Peppermint Oil
With only a few drops of peppermint oil in warm water, you can stop mud daubers from making their nests around your home. Pour the mixture into a sizeable spray bottle, and spray it on spots where you don't want the insects to visit. Peppermint odor is very active in keeping mud daubers away.
However, you may need to apply this mixture frequently. This is because you could have an infestation as soon as the odor wears off."
From:  https://www.imperialpestprevent.com/post/rid-your-home-of-mud-daubers
