StillGame Posted August 12, 2023 Share Posted August 12, 2023 For those with the electronic door lock that was supplied in 2021( RVLock brand) that may have peeling numbers, here's the fix. The lock has a decal that was peeling on the numbers used for my entry code. I just installed a replacement one piece membrane that solved the problem, took 15 minutes to remove the lock and install the membrane. https://www.rvlock.com/products/upgraded-silicone-rvlock-v4-rh-keypad-membrane?_pos=1&_psq=V4+Durō+Keypad+Premium+Membrane+-+Right+Hand&_ss=e&_v=1.0&variant=42649755713730 V4 Durō Keypad Premium Membrane - Right Hand 1 2 Jeff Simone and Katie Thibodeau 2021 Oliver Elite II Hull # 802 Tow Vehicle; 2018 Silverado 2500HD LTZ Crew Cab 6.0 Liter Vortec Link to comment Share on other sites More sharing options...
MAX Burner Posted August 18, 2023 Share Posted August 18, 2023 Our's is doing the same thing - just ordered the new part. Thanks for the great post! Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
SNY SD UP Posted August 18, 2023 Share Posted August 18, 2023 Same thing happened on our lock keypad, and we did the upgrade as you did. 1 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed Link to comment Share on other sites More sharing options...
Cameron Posted Sunday at 06:55 PM Share Posted Sunday at 06:55 PM Just and FYI if anyone needs to replace their locking door handle. https://www.costco.com/compact-rvlock-keyless-entry-handle.product.4000235045.html 1 2 2021 Elite II #841, 2020 GMC Sierra 1500 AT4, 3.0 diesel Link to comment Share on other sites More sharing options...
MAX Burner Posted Monday at 12:19 PM Share Posted Monday at 12:19 PM It's really a piece of cake to replace - just can't figure why RVLock doesn't use the heavy-duty replacement as OEM for the lock set to begin with??? 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
