Patriot Posted January 6, 2024 Posted January 6, 2024 Heads up if you own an F 150 YM 21-23 with Trailer Tow Max Duty pkg. https://www.cnn.com/2024/01/03/cars/ford-f150-pickup-recall/index.html?fbclid=IwAR3MKc3liwv0-IrlLVP5lHD2c6N3UWCFmmq7R0wA5suIdobPxc2NVzlqSGk Check your VIN here - https://www.ford.com/support/recalls/ 4 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderator+ ScubaRx Posted January 6, 2024 Moderator+ Posted January 6, 2024 There is a quick fix available until a more permanent one is developed and implemented. The recommendation is to use a 20-30 foot length of stout rope and tie off the vehicle to the nearest tree. Sounds like a plan to me! 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderators topgun2 Posted January 6, 2024 Moderators Posted January 6, 2024 Or, make sure that you get into the habit of using your emergency brake! 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderator+ ScubaRx Posted January 6, 2024 Moderator+ Posted January 6, 2024 56 minutes ago, topgun2 said: Or, make sure that you get into the habit of using your emergency brake! Our trucks automatically set them when parked on a slope. 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderators topgun2 Posted January 6, 2024 Moderators Posted January 6, 2024 (edited) 13 minutes ago, ScubaRx said: Our trucks automatically set them when parked on a slope. That's because you paid the "big bucks"😁. To add a bit of fuel to the fire - I'm also aware of a Ford recall on the late model F-150's for problems with the emergency brakes! Apparently this recall is to fix emergency brakes that will "automatically" come on while simply driving down the road! Imagine the looks we Ford owners are going to get when we start simply chocking our truck wheels even without the Ollie in tow? OK all you GM, Chevy and Dodge owners out there - here is your chance to pile it on. But, be forewarned - payback is tough! Bill p.s. I specifically excluded the Tundra owners from the above because it is "common knowledge" that Toyota's never have any "issues" 😇 Edited January 6, 2024 by topgun2 added detail 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
