Fritz
Member+-
Fritz last won the day on September 18 2025
Fritz had the most liked content!
Fritz's Achievements
Hopefully you will never need this, but I would like to recommend a fiberglass repair shop in the Pacific Northwest. Chapman Boat Repair, Inc. (208-323-2484) does fiberglass repairs for many of the local boat dealers. Chapman just did a warranty crack repair in the hitch platform (below the doghouse), which involved grinding out the crack area, reinforcing it with fiberglass, spraying gelcoat, and sanding and buffing the gelcoat. No spray paint was used, which does not age like the rest of the trailer's fiberglass and will eventually stand out. The resulting repair and color match is perfect. I heartily recommend Chip Chapman should you ever be in need of fiberglass work.
Does anyone have a recommendation for replacement weatherstripping/molding that is attached under the doghouse cover?
- 1 reply
- 1
Dave and Kimberly -- here's a long shot, but ... I sometimes leave the trailer hooked up to shore power but set the "ignition charge control" on the inverter to "auto-off." This allows use of 120V appliances without a constant charge to the batteries. Furthermore, I sometimes also turn off the solar to allow the batteries to drift to a lower SOC (for the health of the batteries). I've noticed the Xantrex charger/inverter draws electricity when simply connected to shore power. Thus, if you have shore power connected but everything else turned off (including solar), the inverter/converter could be drawing enough to contribute to a 3% SOC drop per day.
MAX Burner started following Fritz
Checking Blum Undermount Drawer Slides
Fritz replied to Fritz's topic in Mechanical & Technical Tips
I used six #6 5/16 screws on each slide. I also made new holes (i.e., I did not reuse previous holes from which the screws had released). #8 5/16 screws would probably also work. I agree with your strategy of installing additional screws, even if not needed,. This will prevent an on-the-road fix later on. -
You may have already fixed this, but just in case: Oliver uses (at least in our 2021 trailer) a push latch like this: https://www.amazon.com/CampN-Pair-Push-Catch-Replacement/dp/B074WFN45Y?th=1. They work well, and should work well as retrofits on older trailers also. A note of caution: their little tabs can break off if a drawer is forced closed and the latch is not in position to accept the tab, rendering the latch useless. But if the drawer is tilting and not sliding correctly, I would check two things first: (1) there is a flat pin at the back of the drawer that has to fit into a hole drilled into the rear wooden drawer panel. If the pin is not in the drawer then the drawer will not be correctly fastened to the Blum slides. Second, if the front drawer latch (the orange one toward the front of the drawer), is not fully attached to the slide then the drawer will tilt and the slide will not operate correctly. If lying on the floor and installing the drawer, you should see and hear the orange latch click into place. Yes, it looks like the orange latches you have in the photo are the correct ones. Our trailer too has these Blum tandem slides. They are arguably among the best in the business. Blum instructions specify mounting the drawer slides to the cabinet wall with 3 screws. This might be fine for non-rolling homes, but rolling kitchens need more screws. After the first year (and 8,000 miles) several of ours had jiggled loose (leading the slides to move and the drawers to appear tilted). I installed more screws into each slide (after removing the drawers from the slides) and have not had a problem since.
For insulation, there is a layer of 1/4" thick (I think) reflectix installed between the hulls. Mostly installed, I should say, in that insulation has gaps in some corners (such as behind some cabinet areas. Layers of reflectix in our trailer are not taped together at seams, so there is room for air movement at corners and reflective joints. Theoretically, I would love to see more insulation between the hulls (reducing loads on the AC and furnace), but air and space between the hulls is what lets moisture (if present) seep toward the bottom of the hull and out one of the scupper drains. Reflectix helps reduce radiant heat transfer under a hot sun. It probably also helps with conductive heat transfer. There is still ample space between the hull walls, so I'm not sure how much it helps with convective heat transfer. I have found the combination of double hull walls, double-pane windows, and AC effective in hot western weather, at least into the low 100°F range. Our 2021 AC is noisy, but gets the job done. Battery compartment can get warm, especially at high charge rates in hot weather. All of that said, we prefer to seek out higher elevations and/or shade on hot days.
Thanks. How might you do it differently?
Actually, I did have to replace a touch light for which I had installed a shade. I sprayed a little bit of rubbing alcohol around the base of the shade where it was stuck to the fiberglass, wiggled it a bit, and the shade came right off. I replaced the touch light, and reinstalled the shade.
Thanks. Newer trailers (at least our 2021 trailer) have five touch lights. The 4” pipe flanges form a tight friction fit around these touch lights. I did not try the concept with other lights (such as those on the ceiling or in the cabinets). Other sizes of pipe or associated fittings might work well for your lights. Good luck!
Did you use a portable circular saw, or did your jig function as a sled on a table saw? Were your 2x4s attached to the plywood so as to create a channel to hold the pvc pipe?
I’ve replaced two, and then had to replace one of the replacements. Failure seems to begin with flickering or dimming.
Thanks for the correction. I used a couple fittings that I had sitting around from a project I did 20 years ago. And I just checked the Home Depot website—these fittings have become expensive! So, if you have to go buy fittings to cut up for shades you will hopefully find a cheaper alternative to the ABS fittings that I used.
It's a minor issue, but sitting at the dinette or lying in bed we found the touch lights can be glaringly bright. I discovered that a 4" PVC sewer-pipe connector has a flange that is the ideal diameter for slipping over the touch light to create a light shade. To create a shade I cut off the flange from a connector using the band saw. This is the cut end that slips over the light... This is the finished end that becomes the bottom of the shade: The shade slips over the light and stays in place with a friction fit, but a bit of 3M double stick tape provides insurance: Dinette touch light, without shade: Dinette light, with shade: Galley lights, with shades: Shade installation does not appear to have any effect on light operation--they still turn on and off by touch. I suppose that the flanges could be cut with a hand saw (hack saw, coping saw?), which would likely require some additional filing and sanding. Also, the shades could be painted white, but for now we've stuck with plain black.
- 14 replies
- 11
I use an aero press: https://www.amazon.com/AeroPress-Portable-Travel-Coffee-Press/dp/B07YVL8SF3/ref=sr_1_6?crid=2IDH7CBZ1K29E&keywords=aeropress&qid=1698864367&sprefix=aero%2Caps%2C311&sr=8-6. Good coffee, extremely easy cleanup, small storage space required. Takes fine-ground coffee (I bring along an electric grinder); for a large mug the first pour of 170°-water is drip, the second pour is press.
Newbies taking the plunge - Are we missing anything
Fritz replied to Dennis and Melissa's topic in General Discussion
I'm not sure what "normal" is for these inverters. However, there is a charge setting (at least for the 3000 W unit, and I think for the 2000 W unit) whereby you can control charging. When the "charger ignition control" is "off" then the batteries will charge automatically when you plug into shore power. When the "charger ignition control" is in the "auto-on" position the 120 V electrical system is powered, but the batteries do not charge from shore power (the batteries still charge from solar, if available). I know, the names and settings are not fully intuitive.
