Mountainman198
Member+-
Mountainman198 last won the day on August 9 2025
Mountainman198 had the most liked content!
898
Mountainman198's Achievements
Buffing and Waxing my Trailer
Mountainman198 replied to Trainman's topic in Mechanical & Technical Tips
Reviving this thread for those who are not interested in the ceramic path for what ever reason. Thanks Trainman! It works! My gelcoat was beginning to chalk and shadows were present where the Oliver logo was removed in the lower rear. Using a 120v makita rotary buffer, a white Presta wool pad and Meguiars One Step polish, the gel coat is again glossy and shadows have been eliminated. Took about 2 hrs to do the entire lower half of the trailer. Will finish buffing the upper half using scaffolding then apply 3M Marine paste wax by hand. While I wax the entire trailer each year, this is the first time the lower half of trailer has had to be buffed since new (upper half was buffed 2years ago for the first time). Trailer lives outdoors 24x7x365. -
“All” electric with a integrated gasoline generator and a 20 gal onboard gasoline tank? Not on my radar as I prefer simple but I am sure it will appeal to some who are looking for a ICE travel appliance which can be pulled by their EV. The Living Vehicle is more appealing and made in the US. Reported dry weight of 8,350-8,900 lbs. Thanks for sharing, Mike. It is interesting to see how the RV market is expanding.
Happier Camper with LEGO modular interior furnishings
Mountainman198 replied to John E Davies's topic in General Discussion
They used to make a larger model called the traveler. I came real close to buying one seven yrs ago from a dealer in Denver (same dealer that used to sell Olivers). Price on this particular new HC traveler was less than $30k but there were several issues with fit and finish that I was not comfortable with (e.g. big gaps around door when closed, modular cubes were warped). Nice little trailer and I hope the quality issues have been resolved. -
Perhaps you could place two treated, upside down blue solo cups into the holders on one of these drinking hats for when you go hiking? Think of the conversations you would have along the way 🤣 Keep having fun and sharing.
I don’t think so. Rat fur, steel frame, 6,000# GVWR torsion bar suspension, plywood cabinet doors and a interior which makes me think I am in the cuddy of a cheap 70’s fiberglass motorboat would keep me from buying it. Btw, I disagree that Oliver doesn’t compete with Airstream as that was one of my other choices and I would have gone that route were it not for their lack of insulation, thin aluminum skins, popping rivets and problems outlined by current owners. Airstream interiors are sexy but only until they begin to come apart. Also, they are not that much lighter than a E2. According to Casita, a 24’ with zero options has a dry weight of 4,250#, 4,600 with all options.
One of my trucks has the double door 4 and 7 pin receptacles shown in the pic. When using the 7 pin, the door blocks the 4 pin access. A solution is to add another flat 4 pin connector behind the 7 pin (plug and play and doesnt affect existing 4 or 7 pin connector use). I have used one of these before and they are a 5 minute install
If the axle(s) on your small trailer were torsion axles with a 1” drop, flipping them would get you 2” of lift. Perhaps this was the case?
Cabinet instead of Stock Convection Microwave
Mountainman198 replied to HDRider's topic in General Discussion
Check with service. They may have some of the interior cabinet shells, frames and lexan doors that were left over from when they offered the microwave delate as a build option. I ordered the cabinet and it has a nice gelcoat interior, light and frosted lexan door with matching chrome cabinet pull and hinges -
CGI offering PPF on the front
Mountainman198 replied to rideadeuce's topic in Mechanical & Technical Tips
For the do it yourselfers, you can buy 12” wide rolls of 3m clearbra and install it vertically on the lower front leading corners (below belly band) of the trailer hull. All you need is a spray bottle of soapy water, some spray alcohol and a squeegee. Since this area gets the most stones as it is directly behind the rear TV wheels, this is a simple and inexpensive way to protect your hull from a majority of debris kicked-up by the TV while towing. Mine has been installed since 2021 and is still in good shape and has taken a few stones along 40,000+ miles. Cost less than $40 in materials. -
Mountainman198 replied to Wayfinder's topic in Mechanical & Technical Tips
Do not rotate bolt. Instead, jack up trailer to remove weight from suspension. Grease should then be able to be introduced. This is a common situation and remedy when greasing two rearmost zerks -
Made in USA leaf springs
Mountainman198 replied to Mountainman198's topic in Mechanical & Technical Tips
Couple comments from your observations. Alcan weight rating (capacity) is 2,750 for 5 leaf and 2,250 for 4 leaf. Weight rating is the designed weight at which a spring pack fails. As the same top four leafs are utilized in both 4 and 5 leaf versions, spring rate (a.k.a. “Ride”) remains largely the same even though weight rating is different. Spring rate is amount of weight required to deflect spring 1” when at ride height. While unable to locate any documentation from Dexter as to “buffer” capacity for their springs I was able to locate documentation from LCI (Lippert) which states that there should be a 20% weight capacity buffer between the total weight capacity of a set of their leaf springs and the curb weight of a fully loaded trailer. Reason stated for maintaining this buffer is to accommodate travel over uneven roads, curbs, potholes, dips and other occurrences which could temporarily increase the actual weight on a spring pack. 7,000x .8= 5,600. My trailer weighs 6,200 ready to travel. I chose the 5 leaf Alcans for my trailer and have been quite happy with their performance. I know a few others have chosen the 4 leaf versions and they seem happy with their choice as well. Either choice is a huge upgrade from the RV industry standard (dexter). -
As posted on the Scamp facebook page, but I see no reason why this would not work just as well when towing an Ollie. Available one day only (today, April 1). This bluetooth connectivity capability answers so many issues faced by the typical Oliver owner like tongue weight, having to use Andersen hitch with 1/2 ton pickups, tow chains, and the 2” vs. 2 5/16” ball dilemma. If anyone was successful in getting ahold of one of these during the tight window of availability today, please post your experience with this seemingly too good to be true answer to all issues related to having to physically connect our trailers to our tow vehicles.
See you there for a few days during Big Tent then off to CA for a bit then back thru for a few days during the fiberglas rally. Looking forward to seeing the usual suspects again and meeting some new folks Lance
That’s it
